:( gear box fault - resolved
Received 4,176 Likes
Time to see how good the warranty is on the tranny rebuild! Driving home today - went to accelerate from a stop - clunk, gear box fault
read codes and am getting a P1747 - assuming the 99 codes are the same - pressure regulator 3 malfunction - can I reset or should I reset?
Would it be safe to drive to the shop (10miles) or get towed?
Five pressure regulator solenoids should read between 4.8-6.8 ohm
The three shift solenoids should be between 25-35
Transmission to TCM pressure regulator (3) circuit, open, or short circuit
Transmission internal pressure regulator (3) circuit, open, or short circuit
Pressure regulator (3) failure
Please check fuse #4 (5 amp) in the smaller engine management fuse box in the engine compartment and fuse #1 (10 amp) in the larger engine compartment fuse box,check your brake booster hose and all areas for vacuum leaks.
This is a very common issue, you might even get away with clearing the codes by removing the neagaitve cable and touching to the positive for 30 seconds
sklimii (10-25-2014)
RJ237 (10-29-2014)
Steve, the light on for high temp came on in about a month. I had a one year warranty so I took it back to the shop. The tranny was rebuilt by another shop and the price for the rebuild included reusing the existing harness, not a new one! The valve body was replaced in the rebuild as the old one had a crack. Due to the very high cost of the Jaguar tranny fluid I decided not to have the harness replaced. It would trigger every month or so but cleared with a restart. Now it has been about a year since it triggered, hope it says that way! Yes, others should be aware of the harness issue in rebuilds.
http://www.jagrepair.com/images/TSB/...body%20TSB.pdf
is a pic, our electrical connectors are garbage lol, the moment you take em off crack, snap, pop !
sklimii (11-07-2014)
Craig, I had the tranny rebuilt a few months back and they reused the old harness. One of the connectors on the harness was damaged causing a short - which was seen as a pressure fault in the valve body. they put in a new harness as part of the rebuilds 2year warranty - so far so good!
as aode06 mentions, the connector on the cable harness is garbage. It may be good for a few years but over time (14+years, 132650miles), just like some of the other plastic parts, the heat they are subject to causes them to break down.
sklimii (11-08-2014)
