Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Headlight Glass Lens (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/headlight-glass-lens-295024/)
rh99XK8 Feb 27, 2026 06:47 AM
I have a 1999 Jag XK8 US model and I need swap instructions for changing out the glass lenz on the right front passenger side headlight assembly
Hell-Cat Feb 27, 2026 09:11 AM
Front wheel bearing
Pistnbroke Feb 27, 2026 10:56 AM
Alternator ( WTF)
bladerunner919 Feb 27, 2026 11:13 AM
Flux capacitor
Pistnbroke Feb 27, 2026 11:29 AM
No thats not a Jaguar part ..you fail
michaelh Feb 27, 2026 02:52 PM
Valvoline Universal ATF
Neat trick with the invisible ink :D
AFAIK, the lens is held by a double-sided adhesive gasket which is unobtainium. Clear RTV works well.
motorcarman Feb 27, 2026 03:19 PM
1 Attachment(s)
Jaguar issued a TSB decades ago.
Tha Driver Feb 28, 2026 04:41 AM
Not sure I would trust silicone/RTV. You can get a windshield "kit" - it's urethane "rope" in a coil & I believe you can find it as thin as 1/4". Made to stick to glass. Or use a caulking gun tube of windshield urethane, but that shtuff is nasty & gets everywhere. Make sure you have lacquer thinner for cleanup & wear gloves. Also, it's a one-time use as it will set up in the tube after opening it, no matter how you try to seal it. Gather anything & everything you need to glue & use up as much of it as you can. :p
Hell-Cat Feb 28, 2026 07:06 AM
I used this stuff from Diode Dynamics, apologies for the weird image URL earlier (now fixed) - This stuff works well.
https://cimg8.ibsrv.net/gimg/www.jag...0e7f2fcec3.jpg
michaelh Feb 28, 2026 04:30 PM
Different car, but I used it successfully to bond the headlamp lenses on the Mk2 Golf back to the reflectors a decade or so ago. I guess the aquarium stuff would be better, although they're still fine, touch wood.
Tha Driver Feb 28, 2026 06:52 PM
That's the type of shtuff I was talking about. Never seen it packaged just for headlights, though.
© 2026 MH Sub I, LLC dba Internet Brands
