Help with fascia lights flashing at night.
I've noticed recently that at night when the fascia back lighting is on, when I slow down to a stop, or sit at a light, the fascia and center console lighting blinks out very randomly and not every time. But starting to become more frequent. It's not happening with the the exterior lighting or stereo.
I do have a new battery so it's not that.
Not being familiar with the circuitry, if this was happening to me, the first place I would be looking is either a bad earth connection common for the lights, or possibly dirty contacts in the actual dimmer unit control unit. When the lights start blinking again, try adjusting the brightness and see if this momentarily rectifies the problem. if it does, then my logic would be dirty contact in the dimmer control.
What say the Vets? Is this plausible or am I way off track here?
Tonight, I started my car and immediately the dash lights started blinking. I turned the rheostat while it was happening just to see if it had any effect, but it worked normally dimming and/or brightening the dash depending on how I turned it. Lasted about 30 seconds, and as soon as I started driving there was no more blinking. As with Phil, only interior dash lights blinked, not exterior.
If that is the case I would first try to spray the two instrument cluster connectors with contact cleaner (with the battery disconnected!).
rsa760041
23
09-25-2015 01:33 PM
