Help needed!
My reverse light is out on my 2009 XK. I see two nuts holding it in but when removed still attached. Is the more under the trunk lid liner?
Now I am reading that it is by design that there is only one reverse light and one is supposed to be out! Is this a fact? |
On my 2000 xk8 all of the rear lights are in one fixture , cluster. There are two plastic retainers that stick through the assembly. You just move them sideways a little bit and the whole cluster should pop off.You may have to fiddle with the carpet that is up against it. You should not have to remove any screws. The bulbs are push and turn type sockets.
I have a 2009. Should have added that. Thank you.
Access is through the back and inside the trunk. Check the manual for further details.
Originally Posted by XKJohnny
(Post 1575618)
My reverse light is out on my 2009 XK. ......
Wrong forum. This is the 1996-2006 XK8/XKR forum. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
