How do I disconnect the O2 sensor plug?
Old Sep 29, 2018 | 09:44 AM
giandanielxk8's Avatar
Default How do I disconnect the O2 sensor plug?
I can't seem to find where the driver's side upstream O2 connects to. I was able to unscrew it out but am unable to reach the plug. Following the wire leads to an area I just can't get to.
Any tips are appreciated?
Old Sep 29, 2018 | 10:18 AM
car5car's Avatar
Buy mirror on a stick and a headlight (flashlight which you wear on your head)
Old Sep 29, 2018 | 10:42 AM
fmertz's Avatar
It's on some post directly behind/below the throttle body. The connectors are each pinned on a tab of sorts. You may have to lift the connectors off the tab and then disconnect the sensor lead from there. Another situation where it looks worse than it is (at least for an XK8).
Best of luck, keep us posted.
Old Sep 29, 2018 | 01:41 PM
Thanks guys, I actually managed to trace the wire to its plug after a youtube video of a guy doing the same thing in an XJ8. I then disconnected it and installed the new one. I made sure to liberally apply the copper grease Denso included with the new sensor. After putting everything back together and refilling the coolant, I reconnected the battery and started the Jag. I cleared the codes and drove around for a bit.
The CEL is gone for good! Interestingly, the heat shield that covers the O2 sensor was missing in my car. Is that why it failed?
My next job is installing new OSRAM Xenarc Night breaker Unlimited D1S bulbs that should be arriving some time next week.
Old Oct 2, 2018 | 04:48 PM
vanremog's Avatar
You guys really need to read my XK8 Bible on this forum. This issue and many more are addressed.
twopumpchump
Dec 8, 2016 08:21 AM
Dave1109971
Sep 30, 2015 11:04 PM
hawaiianjag
Jul 22, 2014 01:03 AM
raschwar
Apr 4, 2014 07:35 AM
LedZepplin
Jul 24, 2011 09:19 PM
