How do I know it's level?
Planning to put my 03 XK8 up on jack stands, all 4 corners high enough for me to crawl under it and do some maintenance.
Want to change the trans fluid, grease the rear U joints, repair the parking brake and just general inspection and maintenance.
I'm old and fat so I plan to get it at least 24" off the ground. Problem is my driveway is not level, it slopes slightly either up hill or to the side, not much but enough to make getting the trans fluid fill correct an issue.
Is there a spot on the car where a level could be placed reading both the X and Y axis to be sure the car is level?
Jandreu (07-20-2015)
Jandreu (07-21-2015)
The sill would give you a level front to rear.
The luggage compartment sections arrowed in blue and purple in this photo should give both X & Y.
Maybe not sufficient for a laboratory experiment but adequate for the transmission fluid level!
Jandreu (07-24-2015)
I have done those jobs recently, and they are not entirely comfortable. You are talking about pumping fluid and maneuvering a hex plug on a short extension around a hot exhaust pipe, under the car, engine running all the while measuring temperature. I would definitely think twice before doing that on a driveway with 2 slopes.
Separately, be prepared for some level of frustration removing the existing pan bolts. A bit of corrosion and they strip right off. I found out the hard way that the chisel technique works best to remove them. I would recommend getting the new hardware with the bigger bit, and replace them all. Best of luck. Keep us posted.
Fmertz, my service records from the PO indicate a trans filter and fluid change completed by a dealer at 48K due to a complaint about the common trans squeak when downshifting from 4 th. Car now has 90 K on it and every now and then will squeak if I'm hitting the gas hard with a 4 th to 3 rd down shift, seems to happen more frequently when I'm turning at the same time..as in rolling thru a green light and turning right aggressively.
So, I think I will forgo the filter change and just freshen up the fluid.
That being said, I agree with your overall point. The expensive part is the fluid (if you stick with the LifeGuard), and messing with the fluid is the technical part of the project. Might as well spend a few bucks more and get the filter/pan plus the new hardware. In addition, there is value in inspecting the pan. There are 2 big magnets meant to catch metal shavings, early signs of failure I gather.
Thanks all for the replies and advice.
Will tackle all this in a few weeks and report back.
Honestly the reason I don't want to change the filter is the potential hassle with the bolts and my limited access under the car.
This is a hobby car that gets maybe 3K miles a year put on it, but that being said those are extream wear miles as it's all stop and go with no long trips.
Chuck Schexnayder
33
10-24-2015 10:20 PM
