How to test the hydraulic pump?
Scott,
1) test for 12volts at the connector.
A) ignition on. Have someone press roof down button. Do you get 12volts? Yes goto 2.
B) No: use key in door to try to open.
12volts? No - Check fuse in trunk
2) yes 12volt reading. Does motor make noise?
Gotta run mate let's start here. Tell us results.
John
John
WhiteXKR
04-16-2013 03:36 PM
Reverend Sam
01-15-2013 11:32 AM
