How wide can I go for tyres on 2001 xk8?
Stock tires are more than enough traction,the brand counts.
Be sure your tires are set from the door sticker on the driver door, or passenger door areas, its low.I set mine at 29 psi cold.
As the tire warms up from rotating, the pressure goes up, so the 29psi might go up to 33 psi, still comfortable and sticky to the road.
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
