IDS does not start anymore
Hi All
I used to diagnose my 2000 XKR with an IDS SDD JLR v138 + V131 Jaguar XJ XK XF F Type Mongoose Pro J2534 Diagnostics kit. That worked fine for a while. The procedure was to connect the cable, turn on ignition, start SSD, punch in the VIN and then SSD would tell you that the car is not compatible with SSD and start IDS for you. So far so good, but suddenly IDS does not start anymore. The sequence is the same, but instead of starting IDS, the IDS splash screen pops up for a second and then disappears. No errors or warnings displayed. SSD shows the device ready and connected, vehicle voltage is displayed as well. All right, so I thought maybe my Chinese close decided to give up and I went for another Chinese product and purchased the V154 VXDIAG VCX NANO for Land Rover and Jaguar. That came with an even newer SSD version 154. The result is the same. IDS splash screen pops up and then nothing. So far both suppliers where unable to help me. Knowing that newer is not necessarily better I tried earlier IDS versions, to no avail, same result. I start thinking that there is something wrong with the OBD system in my car, because apart from not displaying the car voltage the result is the same when I try to run IDS with the cable disconnected. However other 'standard' OBD scanners read out just fine, with the exception of the Jaguar specific things, that is. Is Jag specific communication handled by different PINs / protocols? Anyone has any ideas? Thanks, Chris |
One thing to perhaps check is the date on the PC you are running the software on. SDD will "quit working" after some period past the initial release date. I guess the idea being that if you have a subscription and service cars for a living, you will move along to the latest version.
There is a list of release dates by version in this thread: https://www.jaguarforums.com/forum/g...endium-172152/ |
Thanks Charlie
Yes, I checked the date. In fact I'm using a virtual box install from British Diagnosis. That virtual box comes with a script that sets the date back every time it is started. I might be wrong but I don't think this is a date issue as SDD starts just fine. Its IDS which does not want to cooperate. Thanks, Chris |
