Instrument Cluster Inop / Car will not shift out of park
Here's my issue...car starts right up, instrument cluster is not working, oil pressure and battery charge not working (clock is working), the car will also not come out of park. I drove the car yesterday with no issues / warning lights. The only error code that is coming up is on the climate control display (#14, but this is linked to instrument cluster output), If anyone has any ideas...
thanks 1998 Jaguar XK8 Conv. 4.0 Liter Engine |
The instrument cluster is the hub of all communications, and perhaps its computer crashed. Disconnect the negative terminal of the battery for 10 seconds and reconnect it to reset the system.
That was the trick
Thanks...It worked!!!!!!!!!!
Great!!
If it recurs, check your battery. Also check the primary power connections at the battery, the two high power fuses connections behind the spare tire well, and the primary power feed connectons to each fusebox. Sometime the bolts holding down these power connections work loose. |
Welcome to the forum DRB1122,
Now you've successfully got over the Instrument Pack panic, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum. Graham |
GGG, I went through the new member intro yesterday before posting...I am trying to add a picture and the other information but it says I can't access the area?
Originally Posted by DRB1122
(Post 684278)
Are you trying to add pics to a post here or to your forum user profile? Graham |
