Intake Tube Alternatives
Has anyone found a metal intake tube alternative that isn't the Mina gallery one? I went through a couple plastic ones that kept getting cracked, so I figure I would get the Mina and just not worry about it. Well, the aluminum won't break, which is good, but the thing is annoying in other ways. The way it's designed, it fouls on the hood at multiple points (on top of the throttle body and at the full load breather, which they have put at 90 degrees rather than at an angle). I am getting sick of it. Does anyone know of any alternatives? I can't find any.
make your own out of silicone.
that or just get a new plastic one. |
Thanks. I already have a new plastic one. I'm wondering if there's another metal one out there other than the Mina one. I'm expecting the answer to be no, but maybe someone knows something I don't. I'll probably just bring the Mina one to a metal fabricator and have them deal with it.
I have the Mina intake and it doesn't foul on anything.
Originally Posted by kevh
(Post 2369431)
Trust me, I've tried fiddling with the orientation for the last year. The issue isn't gonna go away. It's just too tall on the throttle body, and the silicone elbow is trimmed as much as possible. I can twist the tube so the full load breather is a little lower, but then the tube comes in contact with the valve cover. |
Thinking about it, it did slightly foul on the lower lip of the bonnet/hood vent so it popped it out when closing but 2 mins with the dremel put that right. As you say there must be some slight differences but you would expect Mina to be aware of that.
I installed my Mina Gallery aluminum intake kit in April 2019 and have never had an issue with it. One of the best improvements I have made to this 2006 XK8....
I think I'm just going to leave it for now. I've been running it for the past year and a half. Got other more substantive things to worry about with the car now.
(Post 2369585)
I'm thinking of getting the Mina intake for my early serial number '97 coupe. How hard was it to install?
Originally Posted by ozbot
(Post 2371760)
Just to note, as EnjoyEverySandwich said, there may be some slight differences on the very early cars which make it more difficult, I wouldn't know about that. |
(Post 2371760)
Also car is an August 1996 build car (VIN ends in 002220), if that helps
Originally Posted by EnjoyEverySandwich
(Post 2371908)
Sounds good. I imagine they'll say it'll work fine. I am curious to see if you have the fouling issue as well.
Also, I promise you can install it yourself! If I can do it, anyone can. |
Right on. I read the other threads concerning the height that the tube sits when installed. I'll know more when I have it in my hands. If worse comes to worst I have a reciprocating saw and a wide array of hammers so....
(Post 2371936)
| All times are GMT -5. The time now is 05:38 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
