Jag XK8 ABS module removal (1997)
Having the ' well known' problems on my XK8 of the ABS warning and traction control warning coming on. I have taken out and cleaned all 4 sensors but to no avail. The next step will have to be taking out the ABS control module and re-soldering the problem areas on the board or sending it in for repair.
I am not keen on taking off the brake lines from the block and then having to bleed the system. Anyone have experience taking the module out without disconnecting the brake pipes? |
Welcome to the forums iankke,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post technical questions about your vehicle Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
