Jetbiker - intermittent Transmission Fault warning.....?
1998 Jaguar XK8 - I was having problems selecting drive the select lever had to be coaxed from park into gear.
My Jaguar workshop replaced the gearbox sump the original one was leaking oil and fitted a replacement rotary switch. The oil levels are correct.
Despite several diagnostic checks and some cable adjustment, when moving the gear lever from Park though reverse to Drive and back to Reverse there is a clunk and a warning light shows gearbox fault. If I switch off the ignition and restart the engine the fault is cleared. Other than that the car drives OK through the gears when motoring.
Does anyone have any suggestions for me please ????
Welcome to the forum Terry,
Not a good plan to put full address details on a public forum. Poole, UK is sufficient for your Location.
The transmission experts will be along shortly to offer advice.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Jetbiker (07-31-2014)
ericjansen
12-19-2021 12:20 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
