Led Projects
2 Attachment(s)
I managed to upload these two pics of two LED projects I have done two weeks ago. I installed a set of Angel eyes, they fitted pefectly in the small gap between the low beam reflector and lens unit. the mood lights fit behind the dash and are remotely controlled with 30 light settings and coordinate with front and rear footwell lights.
That's a neat effect for the interior but you seem to have misplaced your steering wheel.
I like the angel eye! (cuz I can only see one)
Ha i knew i did something wrong when i put it all back together............
Charlie, Cool effect! How did you open the headlamp lens to install the angel eyes?
You do not have too. There is a small gap between the Low beam reflector and the lens assembly and that is were the LEDs sit, you can super glue them on or fix on with double sided tape. you still have to remove the lens assambely from the car and the bottom bolt on it is a right B******
