Lost the heated seat on driver's side
To cure an intermittent airbag light, I disconnected and reconnected the large yellow chock block under the driver's seat.
It cured the airbag light but now I have no heated seat on the driver's side. I guess I disturbed something under there? Does someone have a wiring diagram to indicate if this same block carries the cables for the heated seat? There are several connectors under the seat. Thanks! |
1 Attachment(s)
here ya go
I would only DE-PIN the circuit for the airbag light, but not the heater. And tape up the wires.
Check the harness and connections to the Driver's Seat Module.
Graham |
