no cruise control
getting check rear lights and no cruise control. saw gus reply in 2012 about replacing the brake switch.on an earlier model. was wondering if you feel that it is the same problem in my 2006?
thanks all for being here. |
Yes, the 2006 is the same.
thank you. on one hand hppy to know the fix on the other, 6 3 and just a little space. o well, knew it when I bought it. time to prove the love.
Mine had the same message and no cruise. It was a burnt out rear side marker bulb! Turn on the lights and walk around the car. Every light working?
definitely worth a check. will look tomarrow. mayby there is still hope.
light out, side passager.
So the red side marker bulb replacement restored the cruise control operation?
had an emergency come up. will get back to it asap snd will post results.
my thanks to you all and this forum. |
