Old age and trust issues ‘97 XK8
Boy oh boy. My budget doesn’t allow me to go from mechanic to mechanic and I am unable to do the looking/troubleshooting myself. Question: last oil change a few days ago, my mechanic of 2 1/2 years said my oil pan was slightly “wet”, that “we” may need to change the gasket. Also suggested I drive the car more often and not just around town. Last bit makes sense of course. Any experience with the “wet oil pan may need gasket” being a quick money-maker for a garage? I don’t trust car dealers, real estate people, attorneys, repair garages , my ex-husband, etc. Meanwhile driving car a couple times a week, open highway. On my way to pick up white project boards for under car….
Looks like oil pan gaskets are as low as $11 on eBay. Mechanic may charge say 3 times that. Should not take more than an 1/2 hour to change. Ask for an estimate first.
Many repair shops have a one hour minimum hourly labor charge. Which is entirely reasonable. Even if fixing the issue takes 30 minutes, you are paying for the expertise, not just the exact time it takes. One hour rates can vary from $50 to $100+. You just have to ask for details before dropping off the car.
All that said, if you have a set of drive-on ramps and a creeper, you can get under the car and inspect the oil pan yourself. That may or may not be easy depending on your physicality. I’m 72. Some days it easy to work on the car. Other days, not so easy. if you are in the “not so easy” category, then owning this car may be expensive. They are no more or less reliable than any other 20 + year old car. It’s not the age of the car, it’s a matter of how well it’s been maintained that determines how expensive it will be to own. Z PS: these cars do not do well if left to sit unused. You need to drive it as much as possible to have the best reliability. When not being driven, the car needs to be attached to a battery tender. That will keep many electrical gremlins at bay. |
Originally Posted by Rosevillesister
(Post 2739569)
Richard |
(Post 2739569)
..... my mechanic of 2 1/2 years said my oil pan was slightly “wet”, that “we” may need to change the gasket. .….
Graham |
oil pan leak
(Post 2739569)
it was less than an hour to replace it. The advice to drive it and not let it sit is spot on. |
Zray; I'm 83. Checked and added trans. fluid to my 05 VDP Saturday using ramps, jack and stands and creeper. Hopefully my shoulders will quit hurting eventually.
(Post 2739569)
Second, these cars don't use gaskets, in the traditional sense. They use mostly the equivalent of o-rings. These are generally easier to install and don't require sealant, at the expense of a somewhat shorter lifespan. And if left to sit too long they will get hard and leak prematurely. The problem is that small leaks may not be serious, but they turn into big leaks. And big leaks can be serious. I've seen lots of cars with failed hoses, or failed belts, because of oil leaks. My point is that your mechanic is 100% correct in pointing out small leaks. It's far better to stay on top of them and fix them when they are small, than to wait until your entire engine bay or undercarriage is coated in oil. Luckily, the lower oil pan of these cars is very accessible and the pan cover is quite easy to remove. If you wanted to dip your toe into the DIY waters, it's a good place to start. There's my 2 cents. |
Suspicion dies hard
You are absolutely correct, I know. And not insulted, at all. Wistful and envious of the people who can do extensive DIY on these cars. I love the car and I tend to overthink. (I could so easily be a Prepper) New service manager at my indie shop… old one always referred to the Jag as “our car”. I’ve had a long year, need to regroup and get back into looking at what the car needs. Thanks, appreciate your honesty!
Originally Posted by Y2KJag
(Post 2740969)
First, let me say that if you can't DIY (not uncommon, and not an insult), and you can't trust your indie shop, you need to find another car. If you think your indie is out to make a quick buck off of you, things aren't going to work out. Either develop a good relationship with an indie shop or switch to a much newer car.
If I remember correctly, forum member BobRoy took you under his wing shortly after you acquired your XK8. I assume he is in your general neighborhood. Have you reached out to him lately?
| All times are GMT -5. The time now is 10:42 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
