Paint and Trim Codes
5 Attachment(s)
:icon_shrug:Hi, I have a 2002 XK8 .I"m pretty sure that the paint and trim codes should be on this sticker but they're not there.If anyone has a car with the same paint or interior trim color can they please tell me the code numbers and what the colors are called.I think the paint is called Sapphire but not 100% sure ?. I need to do some paint work and use leather dye on some worn areas.Attachment 760Attachment 761Attachment 762Attachment 763Attachment 764
2002 Paint and Trim Codes
2 Attachment(s)
Looks a lot like mine. The trim code is NED and the paint is JHM. According to JEPC they were called Ivory and Pacific.
I wonder if your car was originally delivered somewhere other than the US. |
Thanks so much test point. My car is a right hand drive and was in England from new and then privately imported to Australia in 2006. Your car definitely looks the same color as mine.
Cheers. |
Originally Posted by Jag Convertible
(Post 125754)
Cheers. They can give you the correct paint code numbers for the above if you car looks a little different than test points car. I hope this helps you. |
Hi Testpoint, I have the same color codes as you am I correct to assume the carpet color is sable? I'm looking to get some custom floor mats. Thanks!
Sable would be a good word choice but I am unaware of a trim code list that goes beyond paint and leather. As posted above any dealer can print out a build document that gives all the fine details of how the car left the factory.
2 Attachment(s)
Originally Posted by ji9988
(Post 470719)
Attachment 16916 Attachment 16917 I have the same dealer printout for the car as Green Jewel describes and the carpets which look the same as yours were Sable. Graham |
Thanks!!
