Plastic Engine Covers
Old Oct 30, 2014 | 01:49 PM
larueb's Avatar
Default Plastic Engine Covers
I purchased a used set of plastic engine covers on ebay as mine were cracked. In trying to place them on the engine the drivers side (left) has longer tabs on the back than my originals. The parts code is #39022 BB on both. Mine is a 4.0 from '99. Before I take a cut off tool and cut the tabs, did Jag make a change in the engine cover mounts? The tab I am referring to is just a set off from the engine.
Any known issues with this solution?
Thanks!
Old Oct 30, 2014 | 03:58 PM
scardini1's Avatar
Can you put up a picture?
Old Oct 30, 2014 | 07:05 PM
DaveC's Avatar
I don't think your tabs are longer. The old cover probably has the end of the tab broken off. Look in the hole where the tab goes into and see if there is a plastic part in there (it should look like an "X". Just push the old plastic part through and you should be good to go.
Forcedair1
Sep 8, 2025 01:57 PM
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
Sublyminal
Sep 3, 2015 04:48 PM
