Rear Back Rest Seat Has Came Loose
Recently when i was driving my xkr coupe, i had to slam my brakes on, i heard a knock from the rear, i thought maybe my spare had shifted and made the noise as it is not screwed down (screw handle missing). Anyway i have been getting a really annoying squeaky rattle noise since then, after investigating it seems the back rest section of my rear seat has come away at the top and my parcel shelf seems to be loose too. What is the easiest way to secure this, has anyone else had this happen?
You'll first remove two nuts that have black caps over them found at the bottom front of the bottom seat. Ather removal, pull up the front of the seat to free from the studs, thread the seat belt clasps thru the seat and remove. Notice at the bottom of the rear seat back, there are 2 screws that need removal. After doing so, the seat back would ordinarily be unattached by raising up on it to free it from the lip at the top rear of the seat/storage compartment. Yours is already not in the lipped ledge which holds it in place. So, raise it slightly to clear the lip. push it backwards then down. Reattach all.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
