rear seat removal
greenforest56 (03-16-2015)
JagxkFan has shown you the seat cushion fixings.
The rear seat back is secured by two screws (LH arrowed in red). Once these have been removed, lift it upwards to clear the two brackets at the top (LH arrowed in yellow).
There is no direct route through the bulkhead into the luggage compartment as the fuel tank is directly behind it.
The easiest route for wiring is either though the hole for the parcel shelf speaker (if you don't have the premium sound system) or follow the black harness for the third brake light through a small round hole under the parcel shelf directly into the luggage compartment.
greenforest56 (03-17-2015)
davidladewig
09-03-2015 06:32 PM
