Rear Sub Frame Grit Trap
1 Attachment(s)
Cleaning up the undercarriage which I like to do on occasion on my cars as it is a good chance to check for loose hardware, missing fasteners or any other odd potential problems. In doing so on my XK8 I discovered a fair amount of dirt and tar coated road gravel which makes it stick trapped in and on the rear subframe. I would say enough to fill a cigar box from the sub-frame flanges and upper surface. Took about a half hour to get it off the flanges and out of the nooks and crannies. I would think where you have road salt and slush to deal with this would be a nice source of corrosion, and might warrant some attention to keep cleaned out.
I'm on the lookout for a good replacement as they tend to rust from the inside out in the UK.
1 Attachment(s)
https://cimg1.ibsrv.net/gimg/www.jag...e11263cfc4.jpg
I just dropped the rear sub-frame of my 2004 XK8 Monday night and got it stripped down last night. It looked almost as good as yours from below but I was suspiscous of all those places I couldn't see. As you say they look like grit traps. I had nothing wrong with the rear end except it is a twelve year old canadian car, and I figured shocks and bushings are probably due. The attached picture will tell the tale. Parts in for blasting this morning, then I will repair that front rail and get it all powder coated. I am going to put a sealant of some kind between the subframe and the vertical triangle shaped piece when it goes back together. |
Melbec,
Are you aware that repair panels are available in the U.K. for just your problem? I used one and it fit really well and is lot cheaper than replacing the whole sill. Jaguar XK8 XKR (X100) Body Repair Panels Rear Half of Sill | Jaguar XK8 and XKR Parts and Accessories |
Originally Posted by daro31
(Post 1395309)
But you might like one of the new seam sealers. From 3M I think? |
Originally Posted by malbec
(Post 1395288)
I looked under my girls' skirt
12 years old, a bad thing to do. |
Originally Posted by White Bear
(Post 1395770)
Melbec,
Are you aware that repair panels are available in the U.K. for just your problem? I used one and it fit really well and is lot cheaper than replacing the whole sill. Jaguar XK8 XKR (X100) Body Repair Panels Rear Half of Sill | Jaguar XK8 and XKR Parts and Accessories Many thanks. |
1 Attachment(s)
And another rusted mess. I bought another a frame from a junk yard.
Originally Posted by plums
(Post 1395793)
I'm partial to just good old fashioned oil spray.
But you might like one of the new seam sealers. From 3M I think? Eastwood Internal Frame Coating 14oz Aerosol |
