Rear Sway Bar Insulators
I am ready to replace the rear Sway Bar Insulators on my XK8 and I would like to know if the rubber cushion should be on the top or the bottom of the sway bar mount. Here is a picture.
https://cimg6.ibsrv.net/gimg/www.jag...74d7786f65.jpg |
They go on just like you show them, but if in doubt, have a look at this add for the system.
https://www.ebay.com/itm/28404660273...aaf9f3619bdf0d Wayne |
My question is does the rubber stack go on the upper side or the lower?
Originally Posted by XK8 Comfort
(Post 2418524)
The rubbers go one on each side of the lower hole, the right angle end goes into the sway bar with the nut on the inside of the bar.
I could not get mine to fit so I sawed them in half. Half on top, half on the bottom. Worked fine for 3 years now.
TJ |
Yeah, as cjd777 states, it's top and bottom.
You can upgrade with powerflex bushes and they are also top and bottom. https://cimg7.ibsrv.net/gimg/www.jag...91feb0a5d5.jpg |
Kent, check this out. The Energy bushings last far longer than the polyflex.
https://www.jaguarforums.com/forum/x...ight=Rear+bush John |
Just did a quick check for you and for anyone:
$4.00 at Summit. https://www.summitracing.com/parts/e...waAoFKEALw_wcB John |
Originally Posted by Johnken
(Post 2418755)
(Post 2418755)
You'll be smiling soon Tom!
John |
Originally Posted by STLTHMSTA
(Post 2418940)
Thanks, I just ordered some and some upper bushings for my daily driver. TM
Originally Posted by giandanielxk8
(Post 2419009)
You will have to trim them down a bit.
