rear view mirror aftermarket replacement
Hi,
I need a new rear-view mirror ( HNC3133AB ) and I'm wondering if there's a less bulky aftermarket replacement that'll do the same job? I assume there won't be as it controls the headlights, but figured there's no harm in asking. :icon_couchhide: <- the factory one is pretty bulky |
I just replaced the R/view mirror on my 1998 xk8 conv. due to the defect issue. I puchased one with a $100 core charge from Coventry for $195. Looks like it is brand new. Let us know if you need a tel number or anything. BTW: save yourself time. Take a look, count the number of wires on the connection write down the connector's color. This is needed to send you the proper replacement. John
I've got a quote for a like-for-like replacment from a breakers yard for £60 inc delivery, so I'll just buy that if there's no better aftermarket replacements.
https://www.jaguarforums.com/forum/x...acement-17719/
Any help? The rear view mirror with headlamp sensing option is unique to Jaguar. If you are fitting a second hand unit just be aware that it probably is the failure prone liquid type. |
I ended up getting a replacement from a breakers yard for £59 delivered. Well, two, because the first they sent me had the same problem.
I managed to smash my windscreen removing it. Ooops. Got that replaced on the insurance. Anyway, it's all in now, and I have a brand new windscreen. Thanks for your help. |
Slightly loose rear view mirror fix?
My rear view is slightly loose. When I set it into position, it stays there for a while but eventual slips down a bit so my view changes to that of the sub-woofer below the rear glass.
Suggestions to tight that up? There is a ring that has fallen out of it onto the post. To prevent it from rattling, I wrapped it with a bit of black tape. As I understand, removing the mirror can be tough. Do we have to have a rear view mirror in the USA if we instead have a rear view camera display in the navigation screen full time? |
Hello MRobinson,
Do you know if they have any others at that price that will sell and ship to US? I no longer have my original unit so cant get it fixed. |
I got the impression they had plenty. Here's their website - they have an international number listed.
Jagbreakers the best place for quality used and new Jaguar Car Parts and Spares |
By the way, the metal catch that holds the mirror in place was slightly damaged before it got to me, I assume in the removal process at the breakers.
I had a windscreen firm install it for me after I broke my windscreen removing the old one, so they put some windscreen adhesive behind it to keep it in place. |
Originally Posted by scottatl
(Post 1044816)
Hello MRobinson,
Do you know if they have any others at that price that will sell and ship to US? I no longer have my original unit so cant get it fixed. Check the stickies at the top of the page for alternative part numbers - the Acura mirror is an almost exact replacement with an improved swivel joint and gel pack dimming unit |
What stickies are you referring to? I'm new to the forum and don't see anthing matching that description at the top of the page.
Thanks. |
Originally Posted by davidsonce
(Post 1047390)
Thanks. Have a look at my post - should all become clear :0) |
Thanks. That clears things up. What threw me, as a new forum member, was the reference to stickies. I think I've figured those out now.
Sybesma's Electronics (800-456-4265) repairs your original mirror. They replace the liquid with a gel, so that self-dimming is not likely to fail again. Cost is $97, and when they returned the mirror to me, it looked brand new.
Replacement Rear View Mirror
I too used Sybesma's Electronics (800-456-4265) in Michigan when my rear view mirror failed with brown streaks running through it. Their service was fast (i week turnaround) Call them for a service number and then send it to them.
Mine came back looking like a new mirror and it works great! Just be extra careful removing the mirror....you can break your windscreen. |
