Replaced springs, shocks and upper mounts - still low front end
Old May 18, 2014 | 12:29 PM
  #41
Jag#4's Avatar
Originally Posted by dieseldoc
What was the part number of the replacement springs, it sounds like they may have a different spring rate then what you need. They are probably softer springs, could be for a coupe.
I agree 100% that the issue is softer springs.
The part number given me was JLM20712* which is the part number for aftermarket (Suplex) 4.0L N/A convertible with non-adaptive damping.
Old May 18, 2014 | 03:12 PM
  #42
Jacob67's Avatar
I am about to replace my front springs, and this thread scares me a bit. (And I sell aftermarked auto parts for a living).
Suplex are supposed to have these springs, so does Lesjöfors. Any have any experience with Lesjöfors? (Swedish brand, owns plants all over Europe)
Old May 18, 2014 | 06:53 PM
  #43
wiljulrin's Avatar
Does the coupe and the convertible have different springs? I would assume they use the same springs.
Old May 18, 2014 | 07:59 PM
  #44
Jag#4's Avatar
I believe they do use different springs. The convertible is a little heavier, so maybe they need it? In any event, they have two different part numbers.
Old May 18, 2014 | 08:42 PM
  #45
dieseldoc's Avatar
The best way to find out if you have the right springs is to call a Jaguar dealer they will look it up by Vin number. In the SNG Barret parts book they list 2 different springs for the 4.0 liter supercharged coupe and convertible. According to Edmunds model specs the XK8 Coupe curb weight is 3726lbs, the Convertible's curb weight is 3962lbs for a difference of 236lbs. The 2001 XKR Coupe 3785lbs, convertible 4021lbs for a difference of 236lbs. I would be inclined to think there should be 2 different springs for the XK8 also.
Old May 18, 2014 | 09:30 PM
  #46
aode06's Avatar
Agreed, give the dealer your vin number, get the part number, and make sure you ask the parts guy, if the part have superceded into another part number
Old May 20, 2014 | 08:49 PM
  #47
pitifulpluto's Avatar
That look suspiciously low. What does the other side look like?
I did work on a '97 xk8 a while back and when it came in one side was dipping down as low as your drivers side.
When I lifted it up the subframe was broken and that caused the wheel to be practically in the fender liner.
It was still driveable, just dangerous.
It doesn't take much to break these aluminum subframes.
Good luck.
Old May 20, 2014 | 10:17 PM
  #48
wiljulrin's Avatar
Both sides are equally low. I wouldn't expect the subframe to break/bend evenly on both sides.
Old May 22, 2014 | 10:48 PM
  #49
Well that rules out my idea, thankfully so! These subframes are very expensive.
Has your mechanic had a look at it yet?
I am very curious to find out what is causing this. It seems like you have addressed any possible culprits.
Good luck!
Old May 23, 2014 | 05:33 AM
  #50
toaster's Avatar
.......according to you photos Nr.4 and Nr.8 the spring is definitely wrong.
The only solution will be changing them again.
Old May 23, 2014 | 09:43 AM
  #51
Jag#4's Avatar
Unfortunately I think you're right, but what are you basing this comment on? The photos wiljulrin posted do not have any marking on the springs. If it is the low ride height itself, then I agree.
Question now is do we replace with another set of Suplex springs or another brand.
Old May 23, 2014 | 10:06 AM
  #52
toaster's Avatar
Sorry,
i spend my holidays till 6-10-2014, so i can´t post photos of the suspension of my xk8 convert.
Please look here:
https://www.jaguarforums.com/forum/x...photos-102401/
For your safety i think it is better to change to another brand.
Old Jun 12, 2014 | 07:39 AM
  #53
toaster's Avatar
Old Jun 13, 2014 | 01:16 PM
  #54
H20boy's Avatar
I looked at my springs, and I have two yellow stripes. It can be very confusing with so many choices available. Looking at the jaguarpartsdb.com site,
Attached Thumbnails Replaced springs, shocks and upper mounts - still low front end-springs.jpg   Replaced springs, shocks and upper mounts - still low front end-jaguarpartsdb.jpg   Replaced springs, shocks and upper mounts - still low front end-guadin-jaguar.jpg
Old Aug 3, 2014 | 02:43 AM
  #55
azeteg's Avatar
Originally Posted by Jag#4
[*]The aftermarket upper shock mounts from SNG Barratt seem to be good quality; however, they have painted (powder coated?) the threaded studs. This must be removed or you will mess up the threads getting the nuts to tighten down (ask the man who knows).
I ran into exactly the same issue. However, only with the original nuts. They are of the weird "oval" type. When replacing those with regular locking nuts and washers, they went on fine, paint or no paint.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
JimC64
24
May 3, 2016 05:14 PM
aquifer
Aug 29, 2015 04:54 PM
timm525
Aug 29, 2015 04:49 PM
