Replacing drive belt tensioner and pulley
Old Feb 18, 2011 | 11:26 AM
XK8UK's Avatar
Smile Replacing drive belt tensioner and pulley
Hi everyone
Does anyone know where i can find a guid with pics or video on how to change the drive belt and tensioner?
I am looking to do the job myself, is this an easy job? and is there anything i should look out for?
thanks
Hani
Old Feb 18, 2011 | 12:22 PM
daddyo007's Avatar
I have not done the tensioner on the drive belt but have done the pulley. Its should be a matter of removing the center bolt and the whole assembly should come off. I would think there would be a specific locating tang so it goes back in the correct position. Since there are no other parts associated with the pulley you could go in blind. A way to check this idea is to get the new part and look it over, it should be evident what kind of diffuculty you would be getting into.
Old Feb 20, 2011 | 08:53 PM
Gus's Avatar
Gus
This link should help. http://www.gusglikas.com/AutoRepairBeltTensioner.htm
Old Oct 1, 2016 | 07:36 PM
FreemanBarraza's Avatar
does anyone have a real procedural link for replacing the idler pulley and belt on the main accessory drive???
Old Oct 1, 2016 | 08:01 PM
BobRoy's Avatar
Use a 15mm socket on a breaker bar on the idler pulley, top pulley in photo. Then turn it to your left,car's right. This will take the tension off the belt so it can be removed. Remove the tensioner with 13mm socket, under idler pulley in photo, and remove bolt and tensioner will come off. Reverse procedure for reassembly.
Attached Thumbnails Replacing drive belt tensioner and pulley-20161001_174447.jpg
Old Oct 1, 2016 | 08:25 PM
you have to take the supercharger belt off first...
Old Oct 1, 2016 | 08:26 PM
signature was not working
Old Oct 2, 2016 | 08:14 AM
DaveInVA's Avatar
And remember the bolt that holds the tensioner pulley on is reverse thread.
Old Oct 2, 2016 | 11:27 AM
frankc's Avatar
Also remember to make a diagram/ take a photo of the belt where it runs etc.
You may think its obvious when its on but once its off its head scratching time ........... now did it go over or under that pulley?
Good point about the reverse thread.
I changed both of mine when I first got the car. No special tools just my tool kit and a lot of grunting.
Old Oct 2, 2016 | 09:27 PM
johns55's Avatar
This should help if you forget the belt routing.
Attached Thumbnails Replacing drive belt tensioner and pulley-engine-belt.gif
xjrjag
May 21, 2026 09:05 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
dpappyp
Aug 27, 2015 06:31 AM
