Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Secondary tensioner job issue (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/secondary-tensioner-job-issue-92249/)
xkrmaxer Mar 23, 2013 02:10 PM
I took off all the cam caps, but the exhaust cam wont budge when I try to pick it up. The tensioner bolts are out and it moves around easily, but I can't get the exhaust cam to lift up. I must be missing something obvious, because I thought this was supposed to be gently lifted up, and I cant get it to lift at all.
plums Mar 23, 2013 02:35 PM
detailed in other threads ... but suspect oil surface tension .. give the nose a little "tink" with a *small* hammer while pulling up on the gear and it should pop right off
test point Mar 23, 2013 03:09 PM
. . . maybe a small wooden or rubber mallet.
xkrmaxer Mar 23, 2013 03:36 PM
I tried it with no success. I am going to try the crank with a breaker bar.
RJ237 Mar 23, 2013 03:57 PM
Did you rotate the engine to a position where the cam lobes were not in contact or barely touching the buckets before removing the caps?
Norri Mar 23, 2013 04:14 PM
How can you turn the crank?
The crank is either locked with the tool or you have a tie wrap on the chain don't you?
xkrmaxer Mar 23, 2013 05:24 PM
The rear two cam lobes were still in contact. I rotated the engine a little and it worked when I tried it this time. Thanks guys
© 2026 MH Sub I, LLC dba Internet Brands
