security lock module diferend for convertible?
Dear jag lovers.
I need to replace SLM. The model that i have is LJB2600AC/015. It`s not a problem to find it on the ebuy but I have read somwhere that there is a diference between coupe and convertible model. I need it for my cabrio... How can I find out if the part comes from convertible? |
I'm not sure why you need to replace the SLM but. In the boot on the wall where the spare tire is located should be a label that says VCATS that is where the module part number is located.
Now as to coupe or convertible I doubt there is a difference. The reason behind that statement is that the module must be programmed to the vehicle. While programming the module you turn on convertible features and turn off coupe features once the module is programmed then you also have to have all of the keys programmed to the new module. It will still be carrying the key codes from the other vehicle. All that being said you are going to have to have Jaguar dealer or an Independent Jaguar shop with the necessary factory software to do the programming. |
