Shoulder on tensioner bolt
Why is there a slightly enlarged shoulder at the top of the bolt that secures the cam chain tensioner?
https://cimg2.ibsrv.net/gimg/www.jag...d21ab8b896.jpg |
Quote:
The size and shape of that bolt, at the end O the day, will makes sure that the tensioner ends up bolted down in the exact right place... Hard to explain, but the shaft itself would allow for a lot of wiggle room, that slightly wider section at the top of the head of the bolt guides it into the right position on torque down |
I can see how that would work - does it need a corresponding space to fit into - which I didn't notice on the parts I fitted or does something deform to accommodate the extra metal?
The ones I took out don't seem to have the same shoulder but the whole design is somewhat different. |
| All times are GMT -5. The time now is 11:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
