standard entertainment UPGRADE
They say it couldnt be done .....so i did it
i upgraded my standard entertainment system with rockford fosgate 10" subs and kenwood 3 ways and dome tweeters, dash 1.5 from a sequoia and 2.5" pyles to go with the subs |
Any piccies? :)
plenty
i should have taken more ...so correction a few pics but it was easy sorta
:icon_toast:
update
well the stero sounds great it still needs tuning the subs are louder than the front so the sound is uneven. the new problem is that the receiver cuts out at about 14 volume i believe its the 2ohm load
Too technical for me i'm afraid.
Mechanicals are bad enough, but electrics just bring about an even blanker look on my face :confused: Hope you get it sorted to your satisfaction :) |
Originally Posted by rellsimone
(Post 627756)
hey rev
hey rev... 14 is the displayed volume level but now i should add it varies but when i turn up the volume it cuts out but the display and functions remain unchanged just no sound. I'm honored you read my post. Any thoughts Rev also i still have that pesky electrical fault toggled with suspension fault. tomorrow im gonna check to see if a diode blew in the fuse box
ok all is fixed and the sound is incredible even with the amp on all minimum and i havent even tuned it yet and still that big surround clear sound although i might add a small amp for the rear mids (might??)
| All times are GMT -5. The time now is 05:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
