Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Tilt Steering (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/tilt-steering-91317/)
wutitis101 Mar 7, 2013 11:03 PM
Tilt Steering
The telescoping wasn't working in 2001 XK8. Found the telescoping cable was shredded. I replaced the cable. Before final assembly, I tested telescoping feature. It went in and out several times with no problems. I re connected the up and down wiring harness and now nothing works. Up and down doesn't work and telescoping doesn't work. Fuses are ok. When I hit the button to activate up and down or telescoping I hear a click at glove box but no movement. Tried un hooking the up and down harness but still no movement now any way...Any suggestion>?
GGG Mar 8, 2013 02:32 AM
I've moved your question from General Tech Help to the to the XK8/XKR section.
The guys here are best able to offer help and advice on this issue.
Jag13cat Mar 8, 2013 12:28 PM
Steering Column inoperative
Wutitis101;
The steering column joystick goes through the Body Processor (Steering Column Movement portion) located behind glove box, air bag bracket. You may be hearing something, as you describe, from the body processor, a grey module w/104 pins. When you checked fuses - there are three you may want to check: 1.)Driver's side fuse box - #8-10amp, controls joy stick switches; 2.) Driver's side #5-15 amp controls logic to body processor; 3.)Passenger side fuse box #7-20 amp controls motors for up/down, in/out movement.
There are also two grounds 1.) at the steering column switch and 2.) a black ground from the body processor module for the motors.
In sounds as if an open circuit exists, either at the column or body processor.
wutitis101 Mar 9, 2013 06:10 AM
Thank you. I was under the impression there was just the one fuse. Im out of town but will check Monday morning.
wutitis101 Mar 14, 2013 11:02 AM
The passenger side fuse was blown but still doesnt work after replacement. Still same clicking sound. So im assuming i have a broken or loose wire undef the column When I was replaceing it. Will rip it apart this afternoon and see.
Jag13cat Mar 15, 2013 10:26 AM
wutitus 101
Since you had a blown fuse, corrected it, and then still have the clicking noise, I agree, you may have a shorted wire in the column which is blowing the driver's side fuse. Probably need to get into it again and check wiring and grounds, both at the column and body processor under pass. dash.
wutitis101 Mar 21, 2013 01:19 PM
Thank you for all the help JAG13Cat! It was a forgotten black ground wire at the column motors wiring harness. Spade connector and a screw to ground and its telescoping in and out as it should. Much appreciated!!!
© 2026 MH Sub I, LLC dba Internet Brands
