Timing chain tensioners
I own a 2002 xk8. Is there any way of verifying wether the tensioners for the drive chain are the plastic or metal ones without taking the engine apart? Manufacturing date was May 2002.
Welcome to the forums murphy007,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
There is only one sure fire way. Take off the passenger side cam cover (easiest) and look. If it isn't metal body pull the other cover and change them. Any other way is a crap shoot. Is my engine number high enough I don't have some left over in stock part installed?
Check the ENGINE NUMBER/DATE CODE (left side of block behind the engine mount)
bob |
