tire size
i need to get a set of tires-----is there a problem running the same size on all 4 corners--i have standard 2002 xkr rims ----- thanks
tyres
hi there,i have 255/40/18s all round never had eny probs with my bridgestone Potenza runflats but not sure if you can go eny wider than that on the front ,other members may give you a better answer.
Same here, im running potenza's all round with no problems, it says under the centre console what size they should be and mine says 17 245 50 so thats what i have got all round
Originally Posted by mark campbell
(Post 1053045)
The 18" Front Rims would be 8" wide and take a 245/45 Tire. |
You could technically run the same size front and rear, but why? With the staggered width wheels you wouldn't be able to rotate them.
tyres
I agree with that but the extra width does look much better plus that bit extra rubber on the road is a bonus,i would love to no just how wide we can go on the 18s at the front.
Originally Posted by graham11
(Post 1053200)
I'm running 255/35 x20 x 9.5 wide D'Vinci Povatti rims all round on my 2000 XKR convertible and the fronts foul the fender , so I'm getting the front rims replaced with 8.5" wide, and run 235/35 x20 on the front. Ive manage to source matching fronts at 8.5" wide, so I'll have a spare set of rears.
Originally Posted by petes76
(Post 1055109)
Not sure of the offsset, but I need to get the rims off and atake a look. It could just be the springs or even worn out shocks, as the front of the car does slope down.
