Transmission Pan Replacement
Old Sep 16, 2011 | 04:45 AM
Cadillac's Avatar
Thanks Sam, I will add this in your Video Section if already not taken
Old Sep 16, 2011 | 07:47 AM
Reverend Sam's Avatar
The video is already in the FAQs, I believe.
Old Sep 30, 2011 | 06:36 PM
Miami XKR's Avatar
Miami XKR
Unhappy
I installed my new Trans pan today and did everything as your video stated.
I have a BIG problem now. My transmission is skipping into gears.
I will try to describe it as best as possible.
When going up in my gears right when the trans is about to shift I feel a slip and the car revs up about 500rpms then it catches.
Why is this happening?!
Old Sep 30, 2011 | 06:47 PM
It sounds like your fluid is too low. That causes air pockets, and air is compressible, transmission fluid is not. When the air pocket hits the torque converter the engine can spin without a load on it until more fluid gets into the torque converter.
Old Sep 30, 2011 | 06:51 PM
There's an easier way to ad more fluid without having to jack up the car. In the engine bay on the left side of the car there's a hose that goes to the transmission cooler. You can easily disconnect the hose with the engine OFF, then pour some fluid into the hose. It will drain down into the pan. The problem, though, is that you won't know when it's full. You might end up over or under filling it. But, if you're having the problem that you're describing, I'd guess you're at least a liter low.
Somewhere on this site there's a picture that shows the hose I'm talking about. I'll try to find it.
Old Sep 30, 2011 | 06:55 PM
Here's a thread which shows picture of the hose and fitting. This link is to page 2 of the thread. You might want to look at the posts on page 1, too. Good information there.
https://www.jaguarforums.com/forum/x...d-50852/page2/
Old Sep 30, 2011 | 07:32 PM
Bamaman's Avatar
MiamiXKR:
You now see what your dealer will do for you. Their Service Writer is not your good friend--but a highly paid commissioned salesman who's job is to take you for ever penny he can.
An oil change is an oil change--as long as they use a proper filter. If you'd rather use someone else do your maintenance, look for a good independent shop.
I generally use car dealership service departments only for warranty work.
Laying under a car watching the oil drain is therapy for the soul, and sometimes the only peace I get all week.
Old Sep 30, 2011 | 07:40 PM
  #28
Originally Posted by Bamaman
MiamiXKR:
I don't think a dealer touched the car. He bought the parts online and did the work himself.
Old Sep 30, 2011 | 08:18 PM
joycesjag's Avatar
I am with Sam on this one. Sounds like your buddy did not get the right amount of fluid replaced. Did he warm the transmission to the proper temp and run through the gears while in the air?
This link my help you out: https://www.jaguarforums.com/forum/s...plained-37802/
Old Sep 30, 2011 | 08:37 PM
  #30
Also, there was some discussion a while back about whether the 6 liters that comes with the kit is enough to replace what drains out. I used 7 quarts to refill mine. If you only put the 6 liters in, you may be a wee bit short. Especially if any was spilled during the fill up.
Old Oct 1, 2011 | 04:07 PM
  #31
Miami XKR's Avatar
Miami XKR
Sam,
Is it possible to put in a good amount of fluid through the transmission cooler lines?
Old Oct 1, 2011 | 04:34 PM
  #32
Not only is it possible, it's easy. Just look at those pictures. Loosen the nut on that S-shaped hard-line, tilt it upward, and pour in the fluid. Use a funnel with a small spout, and leave a little air gap, otherwise the fluid will back up in the hose. Remember, a little bit of fluid is going to drain out when you loosen the nut, so have a rag or something underneath it. Doing it that way is SO MUCH easier that trying to do it from underneath with the engine running.
Oh yeah... when you do it through the cooler hose, DO NOT run the engine. Otherwise you'll have transmission fluid squirting everywhere.
Old Oct 1, 2011 | 06:14 PM
  #33
Miami XKR's Avatar
Miami XKR
Ok, I just did the job. You were right, very easy indeed. I put in 3 quarters of a litter. Hopefully this fixes the gear skipping.
Old Oct 2, 2011 | 03:42 AM
  #34
Jochem00's Avatar
You just poured in 3 qrts, but you still don't know if the fluid level is correct too low or too high.
You better verify the level before it is too late and have to spend 1400 usd instead of 400 usd the dealer quoted for the fluid change.
Make sure the level is correct!
Old Oct 2, 2011 | 09:14 AM
  #35
He put in .75 liters, not three quarts (I thought that at first, too.) If his fluid was so low that the pickup tube was sucking up air, then I doubt he has over-filled his transmission. I agree that the fluid should be checked the correct way, but a little driving will confirm whether or not his fluid level was the problem. If it's still hesitating during shifts then he has a completely different problem. If it's shifting properly now, he can lift the car, pull the plug, and measure the fluid level the correct way using the temp.
Old Oct 2, 2011 | 09:22 AM
  #36
However... When I changed my fluid and pan a few months ago I used exactly 7 quarts of fluid. Assuming his car and my car had the same amount of fluid remaining in the transmission after the pan was removed, then his car would need 7 quarts put back in. There is 1.057 quarts in a liter, so six liters = 6.342 quarts. If he added another 3/4 liter, then he's pretty close to the ideal fluid level. He might be a little high, but I doubt he's so high that he's going to damage the transmission. HAVING SAID THAT, it would be best to pull the plug and check the fluid level.
Old Oct 2, 2011 | 01:28 PM
  #37
nine7xk8's Avatar
sam, how is that car running since changing the fluid. were you having a gear box fault.
Old Oct 2, 2011 | 02:36 PM
  #38
I was not having a gear box fault, but the transmission was jerky at times and it had close to 90,000 miles in it. Changing the fluid fixed the jerkiness. Unfortunately it didn't reduce the mileage.
Old Jan 3, 2012 | 11:09 AM
  #39
Captain Kana's Avatar
Originally Posted by oldmots
Just to clarify, the 4.0 XKR's had a mercedes 5WA580 5 speed tranny. It too is a sealed type with lifetime fluid. I haven't heard any bad things about it so it must either be really rare or performs well. The 2003- 4.2 XKRs got the ZF 6 speed 6HP26 to get the revolutionary high efficiency planetary gearset and the extra speed to save fuel. I have heard few problems with these either except for the whoop noise they made when the fluid had the wrong modifier that let the E-clutch stick on upshifts. This may have been fixed with the current ZF fluid based on my experience.
Does anyone know where to get a kit, pan-filter, sleeve, and fluid for a 2002 xkr? Its got a leak.
Thanks Dan C.
Old Jan 3, 2012 | 01:01 PM
  #40
Thanks Dan C.
The CTSC - ZF Parts
