Unwilling Remotes
Old Feb 25, 2015 | 11:12 PM
ukdude's Avatar
Question Unwilling Remotes
Hi. Both my remotes have been checked and had new batteries, but the locking/unlocking mechanism still proves very reluctant to operate.
It gets embarrassing to resort to key use and forgetting to be quick enough to put it in the ignition to prevent alarm operating. Other than agility exercises, are there any obvious/normal tips to rectify this?
Old Feb 26, 2015 | 05:42 AM
Both remotes never work or only work intermittently?
If it's never then try reprogramming. If it's intermittent, check the harness/connection to the alarm aerial at the top of the rear screen.
Old Feb 26, 2015 | 11:08 AM
ukdude's Avatar
Default Unwilling Remotes
Your tip has helped, Graham - many thanks, but they seem to need very precise pointing?
Old Feb 26, 2015 | 01:40 PM
That is strange. Having to operate closer to the vehicle or point directly at the aerial is usually an indication of failing batteries but you've changed them.
Old Feb 26, 2015 | 04:03 PM
plums's Avatar
Are the remotes as originally supplied in the UK, or aftermarket replaceements?
The UK and NA markets use different frequencies. Using the wrong frequency results in
correct code, but short range. The NA market fobs have a FCC number on them with
the last three digits being the frequency in MHZ.
The freqency of the antenna is marked in the glass next to the antenna using the
same material as the antenna as a stencil.
Swagguar
Sep 30, 2015 01:34 PM
zdrapec
Sep 25, 2015 05:49 AM
kevinl
Sep 24, 2015 08:25 PM
kabs3012
Sep 12, 2015 10:40 AM
