help with tensioners, left bank is done
guys, I started this morning on the left bank, at the point when I need to lift the lower cam shaft, everything is removed. god damn thing would not budge, i see it separating from the bearing on the right side but other than that even when i try to pull with all my strength, nothing. should i keep applying force up on the right hand side where it is already started to separate.
Originally Posted by reko19
(Post 333685)
Not sure what could be holding the cam in its current state. |
Dennis,
i removed all caps slowly as instructed on this forum, the cam did not move at all. i started pulling up on one end, both ends, etc no movement. finally i saw separation on one end. i then applied quite a force up near the sprocket and the whole thing became loose. the old tensioner kinda popped out, is there suppose to be a spring inside cause i cant find it |
(Post 333699)
Dennis,
i removed all caps slowly as instructed on this forum, the cam did not move at all. i started pulling up on one end, both ends, etc no movement. finally i saw separation on one end. i then applied quite a force up near the sprocket and the whole thing became loose. the old tensioner kinda popped out, is there suppose to be a spring inside cause i cant find it I'm only familiar with the 2nd and 3rd gen tensioners. These both have springs. I think you might have 1st gen; springs in these? I don't know. |
mine is 1997 so it is probably 1st generation, started to put it back together...
(Post 333712)
Somebody will surely correct this if it's wrong. |
many thanks i was going crazy trying to find it
starting to button things up many thanks for your help |
I did mine about a month ago. I have a 2000 MY XK8 with red tensioners. thought they were 1st gen, but might be wrong. I am 99% sure that mine had springs in them. I am at work right now but I will check them later on tonight. Might want to hold up on the "button up" process.
Left side is back together, everything works. I will post some questions later on. Took me forever, thanks everyone for your help. Once I get to the right side I'll know for sure if there was a spring. I got to say, bottom right bolt on the gasket cover is freaking impossible to get to, that alone took a long time.
Few follow-up questions. Someone posted here before regarding cheap-arse plastic used for these cars. Well, one of the coil connectors fell off as I was taking it off:
http://i440.photobucket.com/albums/q...9/xk8/th_2.jpg When putting everything back together I plugged terminals directly into a coil: http://i440.photobucket.com/albums/q...9/xk8/th_1.jpg Is this OK, if not what do I do about getting a replacement. Also, insulation on one of the wires was so brittle that it broke exposing 1/4" piece of copper wire, I just taped it with electric tape. Lastly tubing for a thingy shown below cracked as I was removing it: http://i440.photobucket.com/albums/q...9/xk8/th_3.jpg I repaired it with a heat shrink tubing, could someone tell me what it is for. Once again thank you, this was not a pleasant experience. Hoping the right one will be easier since I now have a bit of experience. |
(Post 333839)
http://i440.photobucket.com/albums/q...9/xk8/th_3.jpg I repaired it with a heat shrink tubing, could someone tell me what it is for. |
Paul,
If the tubing is cracked, what would happen? I think I got it all fixed, but just in case would like to know. Thanks. |
(Post 333863)
Paul,
If the tubing is cracked, what would happen? I think I got it all fixed, but just in case would like to know. Thanks. Just so you know, the coil harness does not need to be unplugged. Unscrew the coil screws, loosen all of the coils from the sparkplugs, maneuver as required to pull all out in one chunk as if you are picking up two handfuls of spaghetti. Rest the resulting mass on top of engine to the rear or down by the rear near the exhaust manifold (on newspaper or paper towel, etc). If you choose the top, remember to move it somewhere else if you have to close the hood during the job. |
Originally Posted by plumsauce
(Post 333867)
Massive vacuum leak.
good idea with the coils thanks |
I just finished my 2000 last week. I also just posted pictured two days ago. Look for my post using the smiley face and you will find pictures of the second generation tensioners and showing cracks where they fail and also the third generation I installed.
EZDriver |
I did see your pics, thank you for posting them it was helpful. Your tensioners did have springs, saw it on the pic. I never found a spring from mine, but the good news is everything is back together and works. I am hoping to do right side on Sunday and will see for sure if there is a spring. My car was manufactured in 1996, title says 1997 so this is most likely first generation.
1 Attachment(s)
(Post 333839)
http://i440.photobucket.com/albums/q...9/xk8/th_2.jpg When putting everything back together I plugged terminals directly into a coil: http://i440.photobucket.com/albums/q...9/xk8/th_1.jpg Is this OK, if not what do I do about getting a replacement. Also, insulation on one of the wires was so brittle that it broke exposing 1/4" piece of copper wire, I just taped it with electric tape. Lastly tubing for a thingy shown below cracked as I was removing it: http://i440.photobucket.com/albums/q...9/xk8/th_3.jpg I repaired it with a heat shrink tubing, could someone tell me what it is for. Once again thank you, this was not a pleasant experience. Hoping the right one will be easier since I now have a bit of experience. https://www.jaguarforums.com/forum/x...nectors-37043/ Here is what I DID find that might be helpful. The Jag V6 uses that same connector on their cam phasors. I have them on my X-type. There is a chance to possibly find them in a scrapyard if you look hard enough. The other option, and what I did on my old XK8 because I didn't really like the idea of putting on more cheap plastic, was to use the connectors from a ~2000 Dodge Intrepid 2.7L. New terminals must be crimped on to use the Dodge (Yazaki) connectors, but the type of plastic and connector design is MUCH better. |
Thanks, I wil look into this. Right now I am inclined to leave it the way I have it connected. Really don't see any downside, unless someone here tells me otherwise. I could probably epoxy or silicone it back together, from electrical connection standpoint don't see any advantages.
I drove mine with at least 1 if not 2 coils that way for a couple of weeks. But long term, I'd just be concerned about the terminals vibrating loose and coming off.
Originally Posted by Andy94SC
(Post 334100)
