What bolt pattern and offset, 20"x9"/10" XKR BBS Sepang
I'm trying to get a replacement front wheel from some guy on ebay. He listed the identical part I needed, but after purchasing the item on ebay he's not sure what wheel I need, despite knowing that I have an 05 XKR and need the 20"x9" Sepang.
He wants to know bolt pattern and offset I guess... what numbers do I give him? Sorry, I tried searching a few times and didn't come up with what I needed. :\ |
It sounds like he may have the 20" Sepang off an XJ and is suddenly worried it doesn't fit the XKR.
I went after a replacement front Sepang for my XK8 and found the XJ 20" Sepang is different. Apparently it's a 49 mm and the XK is a 33 mm. I have absolutely NO IDEA what this measurement means but hope it helps! Graham |
Ah ok, thanks! I'll see if that helps!
The PCD is different too.
X350 Sepang = 9Jx20" all round, ET49, PCD 108x5 X100 Sepang = 9Jx20" front, ET25, 10Jx20" rear, ET25, PCD 120.65x5 Well that's according to my information, might be ET33? You should see the PCD & ET info cast into the back of the spokes. |
