What color is tranny oil in 2003 xkr? (!#@&!)
Last night, I ran over what appeared to be an automotive part of some kind,
(looked like an alternator). I missed it with the wheels but it wound up hitting my undercarriage with a violent thud. This morning, I have a large puddle of some kind of oil, emanating from the center area of the engine. I cannot tell if it is engine oil or tranny oil. I guess I'm just trying to get prepared for the worst. It will definitely have to be towed to the shop. What color is the tranny oil in this year and model? Thanks, guys. |
Most ATF is red.
If you have the Mercedes based transmission, it is RED for sure. Put some newspaper under the car to see the true color, or just lay a white paper towel over the puddle and pick it up again. |
Originally Posted by edtexas
(Post 801823)
Pull your engine dipstick and see the oil level and you can also smell it to compare the fluid on the ground.
Thanks for all the feedback. Did all of the recommended analysis.
Looks like tranny fluid. Bummer. Thanks again guys. |
It's the perfect and easier time to change the fluid than going thru an engine oil pan change.
(Post 802417)
Lifeguard Fluid. Gold - just like the cost!
It sounds like the impact has have cracked the plastic pan/filter unit. Other than an unscheduled fluid and filter change, you should have got away without major damage. Graham |
