What is it which makes the X100 so unreliable?
You are quite right about the Vauxhall Astra, it is a good reliable car. In most respects it has always been better than the equivalent Ford, yet has always been seen as second best. Perhaps it is down to marketing in much the same way that VW have marketed their cars on the basis of reliability. Is there any evidence that they are more reliable or is it just effective marketing? I have friends who have VWs and are sick of people stating 'if only everything was as reliable as a Volkswagen' every time it breaks down. I have a 1994 Fiat Punto Cabrio which we have owned since 2000 and like your Astra just keeps going. It's a Fiat (Fix It Again Tony); it should be unreliable and rusted to dust by now. Interestingly, it does share the ecu and ignition system of the Astra!
The XK Jag is a car like any other, there are good ones and there are bad ones. However, when you pay so much for a luxury grand tourer you do expect it to be more reliable. However, that is not always the case as many of the components are the same as on other mass produced cars. Electronic modules and switches for example are often Ford components. What you do get is a car which puts a smile on your face every time you get in it and still turns heads. I recently took an Audi R8 out for a test. It sounded magnificent, but did not feel as special as the Jag. In fact, while I was out in it, my Jag was attracting attention parked on the Audi forecourt!
My advice is let your heart rule your head and go for it. If is doesn't work out, sell it on. Being in the UK, the main thing to look out for is rust, particularly around the rear arches.
I have never owned a Fiat. But I know people who do and like them. They say the bad reports are highly exaggerated and put forward by people who actually don't own one. I guess you really never know till you owned a car.
To be honest, rust is at the bottom of my worry concernslist. Because it's easier to spot than some electric or electronics problem when buying and also easier to repair.
And I would agree a XK8 is much more beautiful than any Audi, R8 or not.
You are obviously searching for disgruntled former owners and their unfavourable opinions/experiences as opposed to satisfied former owners who quite likely as a result of that satisfaction are also current owners.
As l have already said, l think you are starting this journey from the wrong place.
So I'm looking for realistic owners who will tell it like it is, and it seems they are starting to show up and post. So things are pointing up.
I usually am comfortable swimming against conventional wisdom, but this time I'm with the majority 100%. Lack of maintenance is the #1 reason the XKR / XK8 'S have any substantial bad press. Some cars are designed with notion that the owners won't take care of them. Not these cars, rightly or wrongly, the engineers expected the owners to be bright enough to give proper maintenance.
Rust can be a problem with any car if driven on salt. But the other things shouldn't be happening. Like, I'm getting the impression that the electrics must be lived with and will be headache no matter what.
I owned a 2001 XK8 4.0 Coupe for four years followed by a 2005 XK8 4.2 for two years so that qualifies me as a former owner. Issues I had are well documented on the forum.
Now we've got my credentials clearly stated, please do the same. What is the purpose and motive behind your post?
I'm also interested to know who would use the term MOT and then spell tyre in the US fashion. Then the idea of a company keeping cars for fifteen years is extraordinary.
The weaknesses of the XK8 are well known. The main ones are:
1. plastic tensioners
2. cooling system
3. 'sealed for life' transmission
Less frequent are:
4. throttle body TPS
5. corrosion - front floor
All of these have been widely discussed on the forum. Few would make excuses for any of them and certainly not attempt to deny their existence.
From the content of your posts, I don't know why you are even considering Jaguar.
2. cooling system
Less frequent are:
The following 7 users liked this post by GGG:
01Silverstone (02-11-2018),
Dr. D (02-10-2018),
Fulton (02-12-2018),
Jeagar (02-13-2018),
jimmiejag (02-11-2018),
and 2 others liked this post.
The following 11 users liked this post by Jon89:
cjd777 (02-11-2018),
Doug (02-10-2018),
Dr. D (02-10-2018),
and 6 others liked this post.
#28
I live in England, the part of the UK - not New England.
This is the home of the MoT, and 15+ yr old Astras are exceedingly rare. (I hesitate to say non-existent.)
Oh, the Astra - see https://en.wikipedia.org/wiki/Vauxhall_Astra
Companies commonly get rid of cars at 3 years old. I've never met any company with a company car of (say) 8+ years (not counting classic cars owned by companies).
What a weird thread.
#30
As for the purpose and motive behind my post, I thought I was clear enough in my opening post. But I can reprint it here:
I have always loved the shape of the car and I like the Jaguar brand. What has always kept me away was the auto transmission and the horror stories and jokes "if you can't afford a new one you can't afford a used one". For the auto box there seems to be a solution. But I don't want to buy a car, go through the trouble of a manual conversion, just to have to be constantly working on the car just to keep it on the road, because of poor reliability. I want to drive it! ...
And for all the above there are proper replacements or solutions which solve the problem for good? Or is it a case of just keeping replacing them prematurely to keep the cars running?
I saw the gearbox problems thread. But as my interest is a manual swap I didn't look at it. Besides that I tried searching the forums and found fragmented information. And having a fresh thread also opens the door for new solutions to be suggested, which might not have been around last time a given topic was discussed. So with all that, I thought I would start a topic.
Because like I said, I always liked the X100. Even more than the X150.
#31
These are cars we use for company cars. So they take a beating. But they take it well. Based on that and on my experience for the last 16 years, I would have no concerns buying another Astra. But maybe other Vauxhall models are not as reliable? I can't say. Or maybe other or newer generation Astras aren't? All I can say is that at least I have confidence in the name now. No they are not fancy or luxury cars. But I take a car which runs well over some fancy car which is always at the shop and I can't drive.
#32
Received 2,577 Likes
It appears you are adamant about a definition of what is meant by 'regular maintenance'. It can best be defined as maintaining the vehicle according to the manufacturer's maintenance intervals as outlined in the vehicle Owner's Manual.
If you haven't done so already, perhaps you may want to read through the X100 Owner's Manual and become familiar with the maintenance/service intervals for both time and mileage.
Perhaps another Vauxhall may be just the thing since you're readily familiar with the vehicles and know what to expect.
#33
Where?
It doesn't deserve one.
But if you want something that matches the Astra just get another Astra. They're nothing like as great in my experience as you make out, however. I'd put the Astra down as just another car. Not especially reliable or any other metric.
The X100 has more to go wrong and is rather more of a thoroughbred but at least is not in Ferrari territory.
Redline (02-11-2018)
#34
In terms of regular maintenance, mine has an annual service and MOT by an independent Jaguar specialist in Suffolk. The only unscheduled maintenance while in my ownership was the replacement of the fuel pump. I replaced the knock sensor and the wheel sensor myself using the excellent guidance you will find on this forum.
We are a friendly and welcoming bunch despite what you may have thought from our responses (we can also be suspicious of bar room criticism). When you drive one of these cars, it is not just driving a tin box which gets you from A to B, it is an enjoyable journey which will put a smile on your face and if you see another XK look at their smile and give them a wave.
#35
Jaegar, Jaguar's reputation for having reliability issues was well earned prior to time that Ford purchased the company and infused it with cash and with some management discipline. I have owned many cars over the past 50 years of driving, from a new 1967 Camaro 327 with two-speed auto (thanks dad) to current C-Merc, RX Lexus & 2 XKRs. When my wife requested that we buy a new 2003 Type S, I was wary of the marque's reputation for high maintenance expenses particularly because we new the local dealer too well. I bought it anyway and wow. It was the six cylinder, but it had plenty of power for SoCal freeways and absolutely no maintenance issues over first 70k mi. It was totaled in freak parking lot accident and my wife started driving Lexus RX's. I bought two XKRs last year (2001 w/40k & 2006 w/30k) and so far i have had no serious maintenace issues with either. The headrest adjuster on the 2001 is not working properly (minor fix-see threads) and the 2006 has the "check brake lights" code which is probably a burnt out switch (also covered by threads). In every other respect, they look and perform as new. I challenge you to name another 15 year old 390 HP grand touring or sports car (loaded with gee-whiz options of the day) which you can purchase for the cost of a new corolla that can match it. If you want absolutely bullet-proof reliability and low maintenance costs for $20k or less, buy the Toyota Corolla. Like someone said earlier, maybe the XK8/XKR is not the car for you.
#36
Jeagar, you may have been hoodwinked and misinformed by ne'er-do-wells and miscreants. No Jaguar model was included in the venerable Edmunds.com list of "100 Worst Cars of all Time": https://www.edmunds.com/car-reviews/...-all-time.html
Nor did any Jaguar models make the Consumer Reports list of the "20 Worst Cars for Reliability": https://www.usatoday.com/story/money...orst/75275986/
Or even Consumer Reports list of the "Top 10 Most Unreliable Car Brands": https://www.usatoday.com/story/money...-cars/3304413/
All automobiles require maintenance and eventual replacement of time-worn components. Metallurgy and technology continue to improve with lessons learned from field operations, but, by and large, the XK8 and XKR have proven themselves as reliable as any make/model, if maintained. Salted winter roads and simple neglect are what make vehicles unreliable (excluding any vehicle included in the lists above...).
These classic, sexy cars, popular as they are, tend to change owners, who have varying degrees of ability (or interest) in maintaining them. Any 12-to-22 year old automobile is going to need occasional attention, but the fact that they have even remained around for 12-to-22 years is a testament to their reliability. I myself remember when few cars were expected to exceed 5 years or 40,000 miles in their useful lifetimes, but now 150,000+ miles is the norm (with maintenance and replacement of a few aged components). Even most people today wouldn't last much past 55-60 years of age without getting some parts replaced. lol...
Jeagar (02-13-2018)
#37
Looking at the reactions in this thread I'm not sure about that. Only very few actually addressed what I asked and pointed faults. And so far nobody has answered my question about what "regular maintenance" means with the X100 and if it really means regular maintenance or regular repairs.
That being said, I have owned a 2005 XK8 and currently own a 2006 XKR among other Jags (see my signature below). So I suppose I'm both a former and a current owner. My 05 was purchased with 85k miles, sold with 95k miles and my 06 currently has just over 60k on it.
I suppose I will start out addressing the generalization of a "bad reputation." Frankly, I feel that sentiment is carried over from the Leyland era. After the infusion of cash from Ford, the quality really improved. I can say that my Leyland-era Jag, my 87 XJ-SC, has certainly been more problematic than the X100s. But lets focus on those.
Over the 3 years and 10k miles I had the 2005 (keep in mind it was a higher mileage car too), I changed the oil, coolant and brake fluid. New front pads/rotors and new tires. And that's it. Nothing you wouldn't need to do on an Astra or any other car. On the 2006, I also replaced the tires. Changed fluids, and lubricated the rams for the convertible top. A transmission service is coming up. I do have a bent rim, which is a very hard to find BBS wheel and will probably cost $1000 to replace. Other than that, nothing has really "broken" on either of the cars during my ownership.
That being said, buy smart. Both of my cars came with full dealer service histories from new. I think the total of all maintenance and repairs at dealer prices on the 2006 came in at over $20k - thank you previous owner!
As others have mentioned, there will be hoses and other rubber items that are aging and need replacing, as they would with any older car.
But regular "repairs"? Not in my experience, with either of my X100s. I can't say the same for my Land Rover LR3 or XJS - but I still love both of them despite thousands of dollars in repairs needed. Which brings me to the mindset it seems you have, with continually bringing up the Astra.
The X100, although built under Ford ownership, is not a Ford. It's a proper luxury grand touring car, and the sticker on my 2006 was approaching $100k. Certain things, if they break, will be much, much more expensive than a plastic GM product. So, if the idea of possible expensive repairs on a needy, 12 year old luxury car, scares you - then I'd advise sticking with the Astra. You will not have a pleasant ownership experience.
#38
#39
I would prefer hearing from former owners as current owners tend to be protective and just cover things up. Had bad experiences before with other cars in believing forum owners saying the reports were exaggerated and the cars were very reliable. I then bought the cars just to find out they were as much or a bigger piece of s. than everybody said and totally deserved the bad reputation they had. Former owners tend to be more realistic about the cars.
If your own positive opinion of the Astra after 16 years of experience is valid then so too is the opinion of an X100 owner.
It is strange that you would seek to exclude the very people with the most knowledge on the subject and even stranger as to why you so distrust their word.
#40
