Where can I buy the press fit door panel standoffs?
These things tend to break when taking off or pressing on the door panel, where can I get more of them? I also need a new clip nut for the door.
Cheers! |
The only place I've seen them is at the Jag dealer. Most auto parts places sell various little bits like that, but I haven't found any that match. I am using a few of the generic Christmas tree looking ones right now. They work but they aren't as good as the real thing. I'm going to get some more next time I go to the dealer. They are only a dollar or two each.
I got some at Lowes. The are in the drawers in the hardware department. My store has more than one size even.
Can you order them from Lowes? What are they called?
Edit: found them http://www.lowes.com/SearchCatalogDi...atalogId=10051 The pictures are all the same, but the specs page reveal different lengths and diameters, which one is the correctest one? Shipping from Lowe is around 6 bucks. |
Originally Posted by jagosaurus
(Post 393049)
Edit: found them Shop push fastener at Lowes.com: Search Results The pictures are all the same, but the specs page reveal different lengths and diameters, which one is the correctest one? Shipping from Lowe is around 6 bucks. |
(Post 393049)
Edit: found them Shop push fastener at Lowes.com: Search Results The pictures are all the same, but the specs page reveal different lengths and diameters, which one is the correctest one? Shipping from Lowe is around 6 bucks. ALSO, look at the door frame to see if you're missing any of the female pieces. The female bits have a separate part number from the male bits, and it would suck to go to the dealer, buy the male bits, get home, and then realize you needed some of the female bits, too. |
Any chance you could get say 10 for me, and I'll buy the hydraulic pump resistor thingy at the same time? :)
Your right the ones from Lowes are a little larger. I had to trim the outer diameter off a little but they actually fit tighter. They were in stock.
Just a side note---you may want to check clipsandfasteners.com for additional choices. They don't list Jaguar but have literally 100's of automotive clips/fasteners.
(Post 395170)
I thought you were going anyways!
(Post 395170)
(Post 395346)
