Where is trans fill plug on 97 XK8 5hp24 trans
Old Jan 28, 2018 | 10:51 AM
Fairfalcon's Avatar
Default Where is trans fill plug on 97 XK8 5hp24 trans
I have watched the videos of changing the trans oil but they never have a clear shot of WHERE the fill plug is located... anyone have helpful pic?
Mike in TN
Old Jan 28, 2018 | 10:57 AM
phanc60844's Avatar
RHS of the gearbox just behind the exhaust pipe. A cut down allen key does the job, long series if you have it
Old Jan 28, 2018 | 12:20 PM
Fairfalcon's Avatar
Thanks for the reply Phanc,
But I don't have an allen head plug in that location... I have one on the left side (driver side) front that is about a 1/4 inch allen on about a 1/2-5/8 plug... could that be it.??
Mike in TN
Old Jan 28, 2018 | 12:47 PM
RJ237's Avatar
It's near the back on the right side, a couple of inches above the pan.
Old Jan 28, 2018 | 01:04 PM
avern1's Avatar
A picture is worth a thousand words. Here is what you are looking for. By the way to determine full is a special procedure with the engine running and in gear and filling to it barely drips back out.
Attached Thumbnails Where is trans fill plug on 97 XK8 5hp24 trans-trans-fill-plug.jpg
Old Jan 28, 2018 | 01:07 PM
Fairfalcon's Avatar
Thanks guys... I found it... it is kinda hidden by the edge of the pan and exhaust pipe. I will fill per procedure.
Mike in TN
Old Jan 28, 2018 | 02:04 PM
phanc60844's Avatar
' I will fill per procedure.'
Dont be too **** about it, it doesnt have to be exact to the procedure. The trick is to get it warm enough so the fluid is circulating through the cooler so the temperature that is mentioned can be higher but not less. If it was so critical the gearbox wouldn't work on an incline or going round corners!
Timspong
Nov 14, 2017 02:04 PM
thomash85715
May 16, 2016 09:29 PM
Jandreu
Aug 17, 2015 02:43 PM
flydutch
Jun 10, 2013 10:14 AM
vincek
Apr 1, 2010 02:53 PM
