window malfunction on xk8
I have a 98 xk8. I had to pull out all of the fuses and put it back in. Now every time I pull the door side handle on both sides the window automatically goes down until I let go. Its suppose to go down a little then up when the door closes. Any one know how I can fix that problem?
Key on, doors closed, you inside. Hold window switch down until glass is fully down and you hear a slight click (3-4 secs.) Hold window switch up antil glass is fully raised and you hear a click (3-4 secs.) Repeat on opposite window.
Thank you
