Wiring Harness color ID for stock stereo in 99 xk8
I need to identify the the wiring harness colors for the stock stereo.
The wires i have coming out of my harness are.. #1 blue /white #2 purple/yellow #3 red/blue #4 red/green #5 black/green #10 brown/purple #11 yellow/white #12 blue/yellow #13 green/yellow #14 purple #15 purple/white ( pinkish white) #16 purple/red |
Gus's site, jagrepair.com, has the wiring diagrams.
http://www.jagrepair.com/images/Auto.../jagxk1999.pdf |
Thank you Bobroy....i will check that out.
Ok if i can just find out if anyone knows which one is the hot and which one is the ground. Choosing from the colors listed in the original post . Or a site that shows the colors of that harness. Didnt have much luck with the site already recommended.
Just used the site. It shows #10 brown / purple as power.
It shows a braided wire or cable as the ground. It is proably a braided cable from the radio to the chassis separate from wiring harness. |
I also need one set of speaker wire colors...for some reason that site doesn't seem to work for me.
It takes time for the file to upload also it is a PDF file and you may need to upload a PDF reader to your system.
Originally Posted by Debbie Bean
(Post 1570864)
Thank u gus & bobroy...😆
