X100 undertray rubber strip replace
My front undertray is reparable but the rubber strip/lip that sticks down across,it is a goner. Looking for a replacement. I don’t even know what to call it. Any help is much appreciated. Thanks!
Originally Posted by Bobbydrums
(Post 2845339)
Same issue. Let me know if you have any success.
Does anyone have the exact measurements of the profile on that rubber strip?
I have found sevral alternatives that seems to be very close to an original strip among water barrier strip/seals for shower/bathrooms with very little to no trimming. /E |
I found fender flare cover rubber strips that are 1 1/2 inches deep. It may be softer than the original strip, but I think it will look fine. I’m going with that. If anyone finds the perfect stock-similar strip let us know. Thanks!
Where did you locate this? I need one for my ‘04.
Need one also. Dimensions?
Originally Posted by Orthodixie
(Post 2850515)
Length: 860 mm Height: 14 mm Small lip: < 2mm (probably unecessary but it's the small lip you can see on the bottom left in the drawing Depth: 13 mm Lip depth: 4mm https://cimg7.ibsrv.net/gimg/www.jag...bda6205f6c.jpg https://cimg8.ibsrv.net/gimg/www.jag...ac6c4a254d.jpg |
How do you propose to install it?
https://cimg2.ibsrv.net/gimg/www.jag...7312fdae6.jpeg
I have way too much if you want to buy some from me at my cost plus per foot plus shipping. It is soft rubber, so it won’t be damaged if you bottom out on something… plus easily trimmed to shape edges as you like. https://cimg3.ibsrv.net/gimg/www.jag...31e406c7f.jpeg It has un-needed adhesive on back side. I’m not sure if I will rub something on it to eliminate stickiness(Oil or Dirt maybe)… or stick something on there. |
Hi Othodoxie. I’m going to sand the mounting recess with about 180 grit paper and use two-part epoxy to mount it from the top sideways edge. I’ve had good luck with epoxy for adhering.
| All times are GMT -5. The time now is 01:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
