xk8 gearbox fault message
showing codes p0730, p0720, p0734. Transmission shop guy said that speed output sensor and that i have to change computer as well and that has to be done by jag dealer….is this true, does anyone know where speed output sensor is located? I hate going to dealership as usually they give it to me with sand and glass as lube…..kinda painful….help?
If you have a 4.0 L with the 5HP24 the following will be of use:
https://www.jaguarforums.com/forum/x...rmation-78132/
You do not have to remove the transmission to replace, just the valve body. Do that first to see if you really have to replace the TCM, which I doubt. But if you do, get one with exact matching numbers and it may be plug and play. I bought a spare and it works fine.
If you do have to get a refresh, many independent shops can do this.
Please visit the new member area and introduce yourself and your car:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
philwarner
25
06-26-2021 05:43 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
