The XK8 Lucas on me.
While I was testing the fans after installing the third fan relay, I went for the key to turn the engine off.
I was sitting on the door frame and felt I didn’t turn the key off properly. I look at the cluster and noticed a couple of warning messages, some being the door and hood open and read one for the traction control. I decided to turn the engine off, but it wouldn’t shut down! I try a little white grease thinking the mechanism got stuck and also tried turning the key slowly. Nothing!! While turning the key to the off position, when I pass toward the 2 position, I could hear something clicking on the passenger side of the car, maybe a relay? I could even remove the key, I didn’t try to lock the steering wheel, and the engine would not stop. I tried with the extra keys, nothing. I disconnect the battery, ground first, and the engine keep on running. I did a quick glance in the forum and found a suggestion to remove the pump relay, found the location in the manual, trunk box number 4 and I pull it out. The engine stopped and everything went off. Went inside for lunch, Cochinita tacos with habanero, lime and purple onion salsa and a blond cold beer. This has never happened before. What did I do lately? Yesterday I installed the Discount Car Stereo Bluetooth system (between the CD changer and the radio) and today I installed the 3rd fan relay. Maybe the ECM got enough with the intruders and decided to Lucas on me? I decided to replace the new relay with the old donor we installed last. But I found a procedure to do a hard reset and went for it first. After a few minutes I reconnected the battery, started the car and it run no problems, then turn off the ignition and the engine turn off! Any ideas? I’m a little worried installing the RealGauge, will this interfere with the ECM? |
Originally Posted by san_arthur
(Post 2415322)
I have RealGauge and the Discount Car Stereo bluetooth installed for about a year now and have not had a problem.
I am thinking this may be triggered by the fan relay or a mistake on your part when installing any of these components. Has it happened again? |
(Post 2415322)
.....The engine stopped and everything went off.
Went inside for lunch, Cochinita tacos with habanero, lime and purple onion salsa and a blond cold beer. ..... I’m a little worried installing the RealGauge, will this interfere with the ECM? Graham |
Thanks for the info.
Originally Posted by bladerunner919
(Post 2415332)
No. The gauges don't send information or data to the ECM, so the ECM has no idea what is happening upstream from it.
Originally Posted by giandanielxk8
(Post 2415370)
Originally Posted by GGG
(Post 2415375)
I can't recall anyone detailing the lunch menu in the middle of a Jaguar crisis. Not a word I have ever needed to use before but that is definitely COOL. :icon_beerchug:
Graham |
AFAIK, The XK8s/XKRs use Nipondenso Electrics, Not Lucas.
I believe he referenced Lucas as a joke....
Lucas, the prince of darkness.
Originally Posted by Jon89
(Post 2415588)
https://live.staticflickr.com/65535/...cce2b9a489.jpg |
Do not invoke Lucas...
After installing the Real Gauge I went to the trunk to properly connect the battery, placed the floor cover, close the trunk and went inside the cabin and..
https://live.staticflickr.com/65535/...54bdd1184f.jpg https://live.staticflickr.com/65535/...60fef706f2.jpg https://live.staticflickr.com/65535/...31a23c7e33.jpg All the instruments were lit, like when you open the switch before cranking the engine. Inserted the key, move it and nothing. Went back to the trunk, reconnected the negative, went back to the car and everything was off, as it should. Try to start the car and the engine does not turn, I drained the battery. Over the weekend I installed the blue tooth and he Real Gauge. I only run the engine for maybe 20 minutes to check the temp gauge movement. Will a low battery cause electrical problems? I have the battery on the charger and will test it and replace it if necessary. If is not the battery should I suspect a bad key switch? |
(Post 2415634)
..... Will a low battery cause electrical problems? .....
Graham |
wires and cables in the trunk
While replacing the battery I found this cables in the corner of trunk by the battery. Any idea what they are for and if they should be connected?
https://live.staticflickr.com/65535/...bf0e78fd76.jpg https://live.staticflickr.com/65535/...12d46b20e9.jpg This one is intriguing it looks like it was connected before. https://live.staticflickr.com/65535/...f44538288d.jpg https://live.staticflickr.com/65535/...fcd6f155fd.jpg Any information would be appreciate it. |
Those are the cables used to maintain power to the factory battery during the long sea voyage required to ship the vehicles here to the U.S. You can ignore them....
(Post 2415567)
It was delicious, needed to be mentioned! Thanks for your lines.
(Post 2415634)
(Post 2415332)
Lunch and beer on us
Originally Posted by SamtheSham
(Post 2415916)
If you are buying lunch, I will come lend a hand????
Changed the battery
We called Autozone ahead to make sure they have a new battery charged and available.
Since is only 5 miles away from home we managed to charge the old battery with a trickle charger. It barely turned the engine enough to start, barely. In 20 minutes we were driving back home. There are no current manifestations of electrical issues. Thanks for your suggestions. |
