XK8 Milage Question
I have a 2000 XK8 with 68,000 miles on it. The instrument cluster is bad, and I've since purchased 2 others. One has 200,000 miles and the other 88,000 miles. I believe the mileage is actually stored on the cluster itself. Does anyone know which chip it is on?
I read an article a while ago talking about changing or reprogramming the chip to reflect the correct mileage, but I can't seem to find it now. Much Thanks, erjent |
Bit of a waste of time to change the milage ...why not just photo the old and the new and on resale you have proof of the speedo change.
I am not sure if speedos can be changed due to an embedded code linked to the ECU |
Are you concerned with the resale value ? If that’s the case, my feeling is you will not see any difference between the value of a 68,000 mile car and one with 88,000 miles.
Take the photos as mentioned by the previous poster ( @Pistnbroke ) and just move forward. Z |
This video shows that it is possible to clone one instrument cluster onto another, preserving the original mileage. I can't remember if they show where the mileage is stored, but IIRC that can also be adjusted:-
This isn't a DIY process though. |
My speedometer and odometer stopped working.
Originally Posted by dibbit
(Post 2811163)
https://www.youtube.com/watch?v=ibvWHVxXuP This isn't a DIY process though. Rpms temperature and fuel gauges all work |
Originally Posted by David Wichmann
(Post 2812033)
Do i need to replace the instrument cluster?
Odometer
Originally Posted by bladerunner919
(Post 2812055)
What exactly are you asking? Do you have a cluster fault?
these are the error codes that came up for my 2005 XK84.2 |
Speedometer not working
(Post 2812055)
if you don’t know why respond??
(Post 2812245)
https://cimg9.ibsrv.net/gimg/www.jag...e870602c85.png
(Post 2812248)
It wasn’t a trick question
if you don’t know why respond?? |
(Post 2812033)
(Post 2812269)
”…..You can't expect people to guess what you're talking about.
Z |
| All times are GMT -5. The time now is 06:49 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
