XKR through tunnel and 4.5 sec 0-60
Old Dec 7, 2011 | 08:35 AM
Frog's Avatar
Originally Posted by Reverend Sam
I'm thinking a need to trade up. I might have to keep the Apollo wheels, though.
Apollos won't fit the XKR.
Old Dec 7, 2011 | 09:06 AM
avos's Avatar
@Jochem00
Am actually using an even bigger tire (285/35/20), which is almost 2% larger (and almost 4% compared to stock), and only when new this one is spot on measured with a GPS/Dyno on my speedo.
Don’t know anyone in the Netherlands for cats i'm afraid, it’s either the UK or US, and if you have cash to burn there is always Arden in Germany.
Old Dec 7, 2011 | 01:48 PM
Jochem00's Avatar
Well, I will have a look at the cat options onceback home for good. Coming months I will still be put of the country more or less permanently.
Anyway, is there anyody else with video's through tunnels etc?
Old Dec 7, 2011 | 02:14 PM
jamjax's Avatar
J00;
Funny you had a snap in front of the Casino already.....looks very sharp....a little more low key than a yellow F-40....thanks.
Those white out plates must be handy when you are blasting past the cameras at the end of the tunnel....have any extra's?
Avos; Thanks for the great info as always.
cheers,
jj
Old Dec 8, 2011 | 02:35 AM
pomosv's Avatar
Not all XKR's have brembos (my 02, or the op's xkr don't, for example), so appolos will fit OK. And even if you do have bigger brembos, you can always use spacers!
Old Feb 10, 2012 | 08:36 PM
Ipc838's Avatar
Amazing pics from Monaco... I also spotted the Fisker Karma to the right of the Ferrari F40... one of the few 2012 luxury cars my N/A XJ can keep up with
Great acceleration times. You know, car mags always noted the same acceleration times between XKR 4.0 and 4.2s, I guess the 4.2 wasn't as suited to the XK. The newer XJR (X350), though, is way faster than the older one (X308).
Old Feb 11, 2012 | 03:18 AM
XKRacer's Avatar
I dunno I think they might fit, there are some 18s that will fit over Brembos, like Hydras, but all 18s can with 15mm spacers, as the Apollos are 19s I would of thought they would of done...
But I wont deny I am not 100% sure
Old Feb 11, 2012 | 05:54 AM
  #28
Originally Posted by Jochem00
..............Aperently it wasn't that easy to hold the camera in one hand and driving with the other...........
If you want to record road trips, a camera mount gives a much steadier image. This is a UK site but similar devices are widely available:
CAMCORDER MOUNTING BRACKETS
Without the camera to worry about, you should be able to shave a couple of tenths off your time.
Poet
Feb 7, 2025 02:18 PM
ricwel
Jun 23, 2023 05:14 PM
revauto
Sep 17, 2020 03:50 PM
CXJ
Aug 29, 2017 08:41 AM
vacolorito
Sep 25, 2015 09:29 AM
