1995 4.0 XJS Engine Temperature
Old 05-14-2013, 08:47 PM
Paul Mackay's Avatar
Default 1995 4.0 XJS Engine Temperature
So after replacing my temperature sender unit my XJS doesn't have consistent temperature when running. I purchased a replacement thermostat but once the old one was out it was slightly different, it had a larger base. I replaced it and refilled the coolant.....started the engine and it ran really hot. The top hose didn't appear to have much water in it and it wasn't that hot even though the temperature gauge was showing right of "normal". I took the thermostat out and refilled again. The engine runs a little cooler but still not consistent. I then attached a OBD II monitor and the engine temperature was around 140 after a 5 mile run. Is that about right? How do you know if the water pump is working properly? I checked the radiator and it appears very clean. The coolant was nice and green.....and ideas? What else could it be, or is there nothing to worry about?
Your thoughts please.
Paul
Old 05-14-2013, 09:59 PM
Spikepaga's Avatar
Hello;
On your 95 the only sender that will work is DAC11079, which is NLA. The other option is to use a resistor on the aftermarket sender.
Personally I think that it's always a good idea to have the radiator rodded, and also to change the fan clutch and thermostat if original.
The best way to get accurate temperature is going to be thru the Obd2 port
brgjag
General Tech Help
17
09-09-2015 07:34 AM
tberg
09-07-2015 07:32 AM
OkieTim
09-02-2015 12:48 PM
XFR_Gold
09-02-2015 12:24 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: 1995 4.0 XJS Engine Temperature
