Tuning XJS Exhaust Sound
Old 09-19-2014, 09:01 AM
JagZilla's Avatar
Originally Posted by jetlag700
So back to the shop and got him to remove the X pipe and kept each exhaust pipe separate, and had him put on a rock mineral Glass pack muffler which is straight thru.............love the sound! If you like I can get you the youtube link and let you listen to the car.
jetlag700,
I'm still anxiously awaiting that YouTube link, and, I think someone else requested a parts list
  #62
Old 09-22-2014, 10:43 PM
gregh's Avatar
Default Exhaust Mods, liking it
I too wanted a little performance and sound from my '89 XJS, so after reading on this forum last year, I first changed out my stock air cleaner boxes and replaced them with K&N system, then gutted both sets of cats and replaced the mid muffler with straight pipe and added 3"X5" SS exhaust tips beneath the bumper.
I really like the difference, and definitely feel more low-end pulling power under acceleration and love the high-pitch 'singing' when launching. I often use 2nd gear to aid in slowing down, and the burbling sound catches attention too.
She's a great old girl, I drive it like it should, having put 44,000 km on it since buying it almost 4 years ago.
The following 2 users liked this post by gregh:
Flint Ironstag (09-23-2014), ronbros (09-23-2014)
  #63
Old 03-29-2016, 12:46 PM
Beavis's Avatar
Appreciate this is an old thread, but I'm interested in continuing this to find the 'right' option for a proper GT car. So, does anyone have any further knowledge gleaned since 2014?
That and I found another video of Mark Hammond's XJS!
  #64
Old 03-29-2016, 04:44 PM
Dave1109971's Avatar
Love that clip! I get to have the Targa Tasmania cars go past my place each year, the cethana - moina run is awesome to watch.
ronbros (03-30-2016)
  #65
Old 08-14-2018, 08:58 PM
fat_cat's Avatar
bringing up an old thread, could one not go under the cage rather than through the cage for a better sounding exhaust? or does something differ from the etypes to the xjs rear suspension. Maybe height clearance?
  #66
Old 08-12-2019, 08:33 AM
celdik's Avatar
Default XJ12 5.3 V12 Magnaflow X pipe + stainless steel pipes
About to finish my home made stainless steel exhaust system with magnaflow resonated x pipe. What do you guys think?
The following 3 users liked this post by celdik:
Doug (09-28-2019), Robert S (01-11-2020), xjsv12 (08-12-2019)
  #67
Old 08-12-2019, 08:39 AM
fat_cat's Avatar
Sounds awesome. I think the xjs needs the x pipe to sound really good.
  #68
Old 08-12-2019, 07:38 PM
lasstss's Avatar
I put a 2.5" custom system in my xjs through the diff cage. No problem. It can be done.
  #69
Old 08-12-2019, 09:07 PM
VancouverXJ6's Avatar
Originally Posted by celdik
Details needed!
Cat delete? Can you take a underside pic or draw diagram? I need that raspy v12 sound at idle.
  #70
Old 08-13-2019, 02:09 AM
celdik's Avatar
-No cats
-Manual transmission (Getrag 290)
-No overrun valves
-All pipes are 2 1/8 inch (54mm) 304 stainless steel
-Only one muffler - Magnaflow resonated X-pipe, part number 11385
There is another video I managed to record:
Dukejag (08-13-2019), Flint Ironstag (09-28-2019), Segfault (08-14-2019)
  #71
Old 08-13-2019, 09:15 PM
Might need a sock over the mic to clean it up but ya that is nice, I get a Big Cat growl at 700rpm-1000, lawn mower till 2500 then raspy ferrari v12 from 3000+ rpm.
You seem to capture the best note, I'm thinking my gutted cats are the issue.
  #72
Old 08-14-2019, 03:33 AM
celdik's Avatar
What system do you run?
From my experience the cats dont make that much difference in the note. I gutted them out long time ago while having the stock exhaust with mid silencers removed - very small difference in the note.
I wanted to achieve more V12ish note, which in case of an XJ/XJS is in my opinion only possible by merging the two sides of the engine at some point (X or H).
I also picked rather small diameter pipes all around hoping to avoid too deep more like V8 muscle car sound, cos I think that just doesnt sound appropriate for the jag.
I am not sure if my amateur ideas did the trick, but I am very happy with the result.
  #73
Old 08-14-2019, 08:02 PM
Gutted cats, same size pipes as you, 2 glasspack high flow mufflers to side exits ahead of radius arms. Stupid of me to toss the stock resonators they would of been better than mufflers.
I KNEW I should of done the X pipe...I have one in a box here, at 5000rpm in 1st gear its a menacing rasp, and the idle/rolling idle grows like an actual Jaguar cat but that mid range where we do normal driving is just lawn mower-ish.
Mine doesn't snap and rasp while reving like yours. I'd start calling them professional ideas you've done better then me lol.
  #74
Old 08-15-2019, 07:52 PM
Brewtech's Avatar
My first XJS had a hard shift from 3rd to 4th gear, so I always drove in 3 while on surface streets. I had all of the mufflers out, and used 4 glasspacks for some growl. The combo of driving at higher RPMs in 3 with the glasspacks made it a great drive and interestingly had an exotic tone to it.
  #75
Old 09-01-2019, 11:05 AM
JigJag's Avatar
Goosebumps!
The following 3 users liked this post by JigJag:
Flint Ironstag (09-28-2019), fried_hippies (06-30-2020), Mike1610 (10-01-2019)
  #76
Old 09-27-2019, 09:46 PM
944xjs's Avatar
sounds awesome! Just what I want... you have the x-muffler... are the rear silencers gone?
  #77
Old 09-28-2019, 09:23 AM
celdik's Avatar
Thanks! just the x muffler and straight pipes behind the axle...no rear silencers.
  #78
Old 09-28-2019, 10:24 AM
944xjs's Avatar
nice! Did you try it with the silencers at all? Wondering how that would effect the sound ... seems the X-Pipe like the E-Type is the key to a good tone.
  #79
Old 01-09-2020, 03:28 PM
Robert S's Avatar
Has anyone tried straight pipe after the cats? I had a Lincoln Town Car with 4 cats once and ran straight pipe to the factory Y pipe and single exhaust. It sounded good without being overly loud. I'm curious how something like that would sound on an XJS.
ronbros (01-10-2020)
  #80
Old 01-09-2020, 04:16 PM
944xjs's Avatar
I’m ready for spring!
Quick Reply: Tuning XJS Exhaust Sound
